LVGL ESPhome Guition ESP32-S3-4848S040 custom firmware -- Installing
On the Git Hub Page (GitHub - alaltitov/display: LVGL ESP32-S3-4848s040 firmware) in the installation instructions its says:
1. You must enable the “Allow the device to perform Home Assistant actions.” option in the ESPHome integration to Home Assistant to control devices. (I get this, just confused by the order)
2. Place all files from src folder into esphome folder of your home assistant. Edit display.yaml file according to your configuration, for example wi-fi and ota fields. Replace entities from home assistant with your own (entity_id).
Does this mean you need to go into ESPHome Builder and add device, do number #1 and then paste in the code as modified in step #2 and then rebuild the project? I apollogize if the answer is self evident to everyone except me! Kindest Regards, Anthony Baker
