Hi all,
I’m trying to create a LVGL display to display a meter. Because my purpose is to reuse this in several displays, the lvgl setup is created in an external package, imported to both esp devices. For my tests, the meter has:
- a red border
- a blue arc
- 10 ticks
In one of the devices, the Meter components are not correctly shown.
In order to try finding out what is happening, I added a few extra objects:
- full page object, with a green border
- “test” red text, centered
- green circle, centered
Except for the Meter, everything else seem to display correctly in both displays.
This is the lvgl setup, imported into both devices:
lvgl:
pages:
- id: energy_wheel_page
width: 100%
height: 100%
on_load:
- script.execute: power_wheel_script
widgets:
- obj:
width: 100%
height: 100%
align: CENTER
bg_opa: TRANSP
border_opa: COVER
border_color: green
border_width: 10
widgets:
- obj:
align: CENTER
width: 100
height: 100
border_opa: COVER
border_color: green
border_width: 10
radius: 50
- label:
align: CENTER
recolor: true
text: "#FF0000 test#"
- meter:
width: 100%
height: 100%
align: center
indicator:
bg_opa: transp
bg_opa: transp
border_opa: cover
border_color: red
scales:
- range_from: 0
range_to: 100
ticks:
count: 10
indicators:
- arc:
color: blue
r_mod: 0
start_value: 0
end_value: 50
width: 10
opa: 100%
This is the display setup in the device that is wrong:
display:
- platform: mipi_spi
model: ILI9341
invert_colors: false
spi_id: spi_disp
cs_pin: 13
dc_pin: 21
reset_pin: 33
transform:
swap_xy: true
mirror_x: true
mirror_y: true
dimensions:
height: 240
width: 320
auto_clear_enabled: false
update_interval: never
This is the display on the device that is shows correctly:
display:
- platform: ili9xxx
dimensions:
height: 128
width: 128
model: GC9A01A
data_rate: 20MHz
cs_pin: GPIO35
dc_pin: GPIO36
reset_pin: GPIO34
color_order: bgr
invert_colors: true
transform:
mirror_x: false
mirror_y: false
swap_xy: false
I tried searching for a similar problem, but I couldn’t find anything.
Does anyone has any idea what could be wrong?
