Lvgl setup for esp32-s3-lcd-1.47 st7789
For anyone who wants to get the LCD just working or working with LVGL, here is my yaml setup for the :slight_smile:
https://www.waveshare.com/esp32-s3-lcd-1.47.htm
esphome:
  friendly_name: Control Panel
psram:
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
# Enable logging
logger:
  level: VERBOSE
# Enable Home Assistant API
api:
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Control-Panel Fallback Hotspot"
web_server:
  port: 80
captive_portal:
# Example minimal configuration entry
spi:
  clk_pin: GPIO40
  mosi_pin: GPIO45
  interface: hardware
display:
  - platform: st7789v
    model: CUSTOM
    height: 320
    width: 172
    offset_height: 34
    offset_width: 0
    spi_mode: 0
    data_rate: 80000000.0
    auto_clear_enabled: false
    backlight_pin: GPIO48
    cs_pin: GPIO42
    dc_pin: GPIO41
    reset_pin: GPIO39
    # lambda: |-
    #   // Draw a circle in the middle of the display
    #   it.filled_circle(it.get_width() / 2, it.get_height() / 2, 20);
lvgl:
  displays:
    - my_display
  pages:
    - id: main_page
      widgets:
        - label:
            align: CENTER
            text: 'Hello World!'
This will display a white screen with black hello world in the center.
If you uncomment the lamda code, comment out the lvgl code. Cannot use both at the same time, compiler complains.
