M5 Atom Echo - Use as a sound meter?
I’m just starting to get into ESPHome and I bought an M5 Atom Echo as my first experiment thinking I could try and get the onboard microphone to get me sound data as a sensor but so far this hasn’t been easy to get working.
Initially I looked at the m5 atom example voice assistant config and just removed the voice assistant portions since I don’t want to integrate that at this stage. It compiled fine and I was able to play around with different light configurations. But just having the microphone component wasn’t enough to provide any information in Home Assistant.
Next I looked at GitHub - stas-sl/esphome-sound-level-meter which could be a way forward, but I was hoping to stick with a vanilla esphome project for this since I’m trying to get my feet wet with ESPhome for the first time and start learning the ropes by tinkering.
My main question is, is there a way to get sound data from the microphone component and expose it to Home Assistant without adding any voice assistant stuff? I see that there are capture actions, and an on_data trigger, but how would I use that to expose useful information that I can work with?
Thanks!
Any luck with this
Curious as well I’d like to use it like a baby phone. I want to hear if one of my kids is calling and I am using the TV with headphones. My oldest gets up so I have a notification on a TV when she goes in the corridor. But my son never gets up alone in the night.
Hi, is there any further progress? I also want to use my M5 Atom Echo to detect sound. Didn’t find any example so far.
I search for the same thing, sound détection .
Why not to use a custom component? The Atom Echo works very well as a sound meter with viotemp1/esphome-sound-level-meter.
I’ve created an example yaml file to use the M5 Atom Echo as sound level meter using the available ESPHome platforms for I2S audio / microphone.
The yaml file is here.
It reports peak and average sound levels every second.
Best regards,
Hollie.
