Trying to connect M5 Atom Lite and ENV-IV sensor, which has BMP280 and SHT40 on the I2C. Both sensors are visible when I run a basic I2C detection script (at 0x76 and 0x44) on the Atom.
this is my ESPHome YAML:
esphome:
friendly_name: Lounge-Atom
min_version: 2024.11.0
name_add_mac_suffix: false
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
i2c:
scl: 21
sda: 25
scan: true
- platform: sht4x
temperature:
name: "SHT40 Temperature"
humidity:
name: "SHT40 Relative Humidity"
- platform: bmp280_i2c
address: 0x76
temperature:
name: "BMP280 Temperature"
oversampling: 16x
pressure:
name: "BMP280 Pressure"
bluetooth_proxy:
During compiling/install I get:
src/esphome/components/sht4x/sht4x.cpp: In member function 'virtual void esphome::sht4x::SHT4XComponent::setup()':
src/esphome/components/sht4x/sht4x.cpp:22:63: warning: arithmetic between enumeration type 'esphome::sht4x::SHT4XHEATERTIME' and floating-point type 'float' is deprecated [-Wdeprecated-enum-float-conversion]
22 | uint32_t heater_interval = (uint32_t) (this->heater_time_ / this->duty_cycle_);
I then get this error after upload
[E][bmp280.sensor:135]: Communication with BMP280 failed!
and finally this when it’s running
[D][sht4x:080]: Sensor read failed
Can anyone suggest where I’m going wrong with this?
