Initially the 2026.7.4 update failed to compile due to some breaking changes in my config,
‘WARNING Captive portal is enabled but no WiFi AP is configured. The captive portal will not be accessible. Add ‘ap:’ to your WiFi configuration to enable the captive portal.’
I added the ‘ap:’ to the yaml. I saved and validated the file, all ok, but the installation failed with the errors below:
FAILED: esp-idf/src/CMakeFiles/__idf_src.dir/main.cpp.obj
ccache /data/cache/idf/tools/xtensa-esp-elf/esp-14.2.0_20260121/xtensa-esp-elf/bin/xtensa-esp32-elf-g++ @esp-idf/src/CMakeFiles/_idf_src.dir/main.cpp.obj.rsp -MD -MT esp-idf/src/CMakeFiles/idf_src.dir/main.cpp.obj -MF esp-idf/src/CMakeFiles/idf_src.dir/main.cpp.obj.d -o esp-idf/src/CMakeFiles/idf_src.dir/main.cpp.obj -c /data/build/m5stack-atom-echo-3183e4/src/main.cpp
/config/esphome/m5stack-atom-echo-3183e4.yaml: In lambda function:
/config/esphome/m5stack-atom-echo-3183e4.yaml:137:41: error: 'class esphome::template::TemplateSelect<false, true, true, 1>’ has no member named ‘state’
137 | then:
/config/esphome/m5stack-atom-echo-3183e4.yaml:240:41: error: 'class esphome::template::TemplateSelect<false, true, true, 1>’ has no member named ‘state’
240 | - switch.is_on: use_listen_light
/config/esphome/m5stack-atom-echo-3183e4.yaml:253:41: error: 'class esphome::template::TemplateSelect<false, true, true, 1>’ has no member named ‘state’
253 | - switch.is_on: use_listen_light
/config/esphome/m5stack-atom-echo-3183e4.yaml:272:41: error: 'class esphome::template::TemplateSelect<false, true, true, 1>’ has no member named ‘state’
272 | then:
/config/esphome/m5stack-atom-echo-3183e4.yaml:281:41: error: 'class esphome::template::TemplateSelect<false, true, true, 1>’ has no member named ‘state’
281 | then:
/config/esphome/m5stack-atom-echo-3183e4.yaml:289:41: error: 'class esphome::template::TemplateSelect<false, true, true, 1>’ has no member named ‘state’
289 | then:
/config/esphome/m5stack-atom-echo-3183e4.yaml:295:41: error: 'class esphome::template::TemplateSelect<false, true, true, 1>’ has no member named ‘state’
295 | then:
ninja: build stopped: subcommand failed.
ninja failed with exit code 1, output of the command is in the /data/build/m5stack-atom-echo-3183e4/build/log/idf_py_stderr_output_28698 and /data/build/m5stack-atom-echo-3183e4/build/log/idf_py_stdout_output_28698
This has worked for a couple of years, why has it stopped?
