OK, I’ve searched and and tried everything I have found but…
Voice commands work but there is no sound. Volume on max, Is this another dead Atom?
Log when activated - “Okay Nabu: What time is it?”
Any ideas folks?
[16:32:02.218][D][micro_wake_word:325]: Detected ‘Okay Nabu’ with sliding average probability is 0.99 and max probability is 1.00
[16:32:02.218][D][voice_assistant:482]: State changed from IDLE to START_MICROPHONE
[16:32:02.218][D][voice_assistant:489]: Desired state set to START_PIPELINE
[16:32:02.221][D][micro_wake_word:370]: Stopping wake word detection
[16:32:02.221][D][voice_assistant:208]: Starting Microphone
[16:32:02.221][D][ring_buffer:034]: Created ring buffer with size 16384
[16:32:02.228][D][voice_assistant:482]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[16:32:02.241][D][micro_wake_word:378]: State changed from DETECTING_WAKE_WORD to STOPPING
[16:32:02.241][D][voice_assistant:482]: State changed from STARTING_MICROPHONE to START_PIPELINE
[16:32:02.263][D][voice_assistant:229]: Requesting start
[16:32:02.267][D][voice_assistant:482]: State changed from START_PIPELINE to STARTING_PIPELINE
[16:32:02.274][D][voice_assistant:504]: Client started, streaming microphone
[16:32:02.282][D][voice_assistant:482]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[16:32:02.282][D][voice_assistant:489]: Desired state set to STREAMING_MICROPHONE
[16:32:02.283][D][voice_assistant:628]: Event Type: 1
[16:32:02.290][D][voice_assistant:631]: Assist Pipeline running
[16:32:02.298][D][voice_assistant:628]: Event Type: 3
[16:32:02.299][D][voice_assistant:650]: STT started
[16:32:02.305][D][light:091]: ‘M5Stack Atom Echo’ Setting:
[16:32:02.309][D][light:115]: Red: 0%, Green: 0%, Blue: 100%
[16:32:02.312][D][light:165]: Effect: ‘Slow Pulse’
[16:32:02.319][D][micro_wake_word:274]: Inference task is stopping, deallocating buffers
[16:32:02.330][D][micro_wake_word:279]: Inference task is finished, freeing task resources
[16:32:02.331][D][micro_wake_word:378]: State changed from STOPPING to STOPPED
[16:32:03.460][D][voice_assistant:628]: Event Type: 11
[16:32:03.473][D][voice_assistant:831]: Starting STT by VAD
[16:32:04.586][D][voice_assistant:628]: Event Type: 12
[16:32:04.588][D][voice_assistant:835]: STT by VAD end
[16:32:04.588][D][voice_assistant:482]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[16:32:04.589][D][voice_assistant:489]: Desired state set to AWAITING_RESPONSE
[16:32:04.598][D][light:091]: ‘M5Stack Atom Echo’ Setting:
[16:32:04.601][D][light:115]: Red: 0%, Green: 0%, Blue: 100%
[16:32:04.601][D][light:165]: Effect: ‘Fast Pulse’
[16:32:04.606][D][voice_assistant:482]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[16:32:04.612][D][voice_assistant:482]: State changed from STOPPING_MICROPHONE to AWAITING_RESPONSE
[16:32:04.625][D][voice_assistant:628]: Event Type: 4
[16:32:04.630][D][voice_assistant:667]: Speech recognised as: “What time is it?”
[16:32:04.634][D][voice_assistant:628]: Event Type: 5
[16:32:04.634][D][voice_assistant:672]: Intent started
[16:32:04.661][D][voice_assistant:628]: Event Type: 6
[16:32:04.665][D][voice_assistant:628]: Event Type: 7
[16:32:04.670][D][voice_assistant:725]: Response: “4:32 PM”
[16:32:04.676][D][voice_assistant:628]: Event Type: 8
[16:32:04.677][D][voice_assistant:747]: Response URL: “http://192.168.1.84:8123/api/tts_proxy/OueohWyFRrQrmwxPZajs-g.wav”
[16:32:04.677][D][voice_assistant:482]: State changed from AWAITING_RESPONSE to STREAMING_RESPONSE
[16:32:04.677][D][voice_assistant:489]: Desired state set to STREAMING_RESPONSE
[16:32:04.682][D][voice_assistant:628]: Event Type: 2
[16:32:04.683][D][voice_assistant:770]: Assist Pipeline ended
[16:32:04.690][D][light:091]: ‘M5Stack Atom Echo’ Setting:
[16:32:04.694][D][light:079]: Brightness: 100%
[16:32:04.702][D][light:115]: Red: 0%, Green: 0%, Blue: 100%
[16:32:04.703][D][light:165]: Effect: ‘None’
[16:32:04.707][D][media_player:084]: ‘M5Stack Atom Echo’ - Setting
[16:32:04.707][D][media_player:091]: Media URL: http://192.168.1.84:8123/api/tts_proxy/OueohWyFRrQrmwxPZajs-g.wav
[16:32:04.717][D][media_player:097]: Announcement: yes
[16:32:04.727][D][light:091]: ‘M5Stack Atom Echo’ Setting:
[16:32:04.734][D][light:079]: Brightness: 100%
[16:32:04.739][D][light:115]: Red: 0%, Green: 0%, Blue: 100%
[16:32:04.751][D][speaker_media_player:410]: State changed to ANNOUNCING
[16:32:05.359][D][speaker_media_player.pipeline:114]: Reading WAV file type
[16:32:05.375][D][ring_buffer:034][ann_read]: Created ring buffer with size 6000
[16:32:05.400][D][speaker_media_player.pipeline:124]: Decoded audio has 2 channels, 16000 Hz sample rate, and 16 bits per sample
[16:32:05.404][D][i2s_audio.speaker:102]: Starting
[16:32:05.410][D][i2s_audio.speaker:106]: Started
[16:32:05.410][D][ring_buffer:034][speaker_task]: Created ring buffer with size 3840
[16:32:07.693][D][i2s_audio.speaker:111]: Stopping
[16:32:07.698][D][i2s_audio.speaker:116]: Stopped
[16:32:07.701][D][light:091]: ‘M5Stack Atom Echo’ Setting:
[16:32:07.705][D][light:079]: Brightness: 60%
[16:32:07.711][D][light:115]: Red: 100%, Green: 89%, Blue: 71%
[16:32:07.711][D][speaker_media_player:410]: State changed to IDLE
[16:32:07.711][D][voice_assistant:352]: Announcement finished playing
[16:32:07.720][D][voice_assistant:482]: State changed from STREAMING_RESPONSE to RESPONSE_FINISHED
[16:32:07.722][D][voice_assistant:489]: Desired state set to RESPONSE_FINISHED
[16:32:07.724][D][voice_assistant:482]: State changed from RESPONSE_FINISHED to IDLE
[16:32:07.725][D][voice_assistant:489]: Desired state set to IDLE
[16:32:07.725][D][micro_wake_word:360]: Starting wake word detection
[16:32:07.725][D][light:091]: ‘M5Stack Atom Echo’ Setting:
[16:32:07.737][D][light:079]: Brightness: 60%
[16:32:07.742][D][light:115]: Red: 100%, Green: 89%, Blue: 71%
[16:32:07.746][D][micro_wake_word:378]: State changed from STOPPED to STARTING
[16:32:07.773][D][micro_wake_word:262]: Inference task has started, attempting to allocate memory for buffers
[16:32:07.775][D][micro_wake_word:267]: Inference task is running
[16:32:07.775][D][micro_wake_word:378]: State changed from STARTING to DETECTING_WAKE_WORD
[16:32:07.795][D][ring_buffer:034][mww]: Created ring buffer with size 3840
