Dear all,
I plan to read my smart meter via SML. Therefore, I bought an M5stack ATOM Lite (specs see here and pin assignment here) and implemented a first program (below) to test the device.
The code allows me to change the LED lights on GPIO 27 via the HA overview and this works fine, but for some reason I do not understand, the button on GPIO 39 does not respond to a press. When I press it, neither the state on the HA overview screen changes, no do I see any response in the log.
Note, I copied the relevant code from here and I assume it should work well from this tested example.
Did I do a stupid mistake below, or may I assume that the button is simply defective?
I use the following code
esphome:
compile_process_limit: 2
esp32:
board: m5stack-atom
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Smart-Meter Fallback Hotspot"
password: "xxxxxxxxxxxxxxxxxxxx"
captive_portal:
## Device-specific
light:
- platform: neopixelbus
type: GRB
variant: WS2812
pin: 27
num_leds: 1
effects:
- random:
- flicker:
- addressable_rainbow:
binary_sensor:
- platform: gpio
pin:
number: 39
inverted: false
on_press:
then:
- light.toggle: status_led
uart:
rx_pin: 26
tx_pin: 32
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
#debug:
sml:
uart_id: uart_bus
- platform: sml
name: "Zählwerk positive Wirkenergie, tariflos"
sml_id: mysml
obis_code: "1-0:1.8.0"
unit_of_measurement: kWh
device_class: energy
state_class: total_increasing
- platform: esp32_hall
name: "ESP32 Hall Sensor"
update_interval: 30sec
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 2min
- platform: uptime
text_sensor:
- platform: sml
sml_id: mysml
obis_code: "129-129:199.130.3"
format: text
switch:
- platform: restart
Thanks a lot for your assistance!
