Is there a working example of how to use the M5Stack AtomS3 Camera (5mp model!) in EspHome?
I get the follow message in the log:
[16:41:56][E][esp32_camera:123]: Setup Failed: ESP_ERR_NOT_FOUND
[16:41:56][E][component:082]: Component esp32_camera is marked FAILED
[16:41:56][C][web_server:285]: Web Server:
This is how far i got until now:
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
esphome:
friendly_name: 95e-Atom-S3Cam
api:
ota:
- platform: esphome
password: "XXXXXX"
wifi:
networks:
- ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.X.XXX
gateway: 192.168.2.254
subnet: 255.255.255.0
dns1: 192.168.2.25
dns2: 1.1.1.1
logger:
level: DEBUG
psram:
mode: octal
speed: 80MHz
esp32_camera:
name: M5Stack CamS3 5MP
external_clock:
pin: GPIO11
frequency: 20MHz
i2c_pins:
sda: GPIO17
scl: GPIO41
data_pins: [GPIO6, GPIO15, GPIO16, GPIO7, GPIO5, GPIO10, GPIO4, GPIO13]
vsync_pin: GPIO42
href_pin: GPIO18
pixel_clock_pin: GPIO12
power_down_pin: GPIO0
reset_pin: GPIO21
#resolution: 1920x1080
jpeg_quality: 12
max_framerate: 15 fps
web_server:
port: 80
Any example of working code in yaml is welcome!!!
