I’m quite new to using ESPHome having only got a bluetooth proxy setup recently.
After updating my HA Green to Core 2025.5.3, I got a notification that my m5stack atom lite should be updated to ESPHome 2025.5.0.
I headed over to the ESPHome ready-made projects which I used to originally setup to Atom Lite as a bluetooth proxy. Only to discover it’s no longer a listed device.
Is the m5stack no longer supported as a bluetooth proxy, is there some other way I should be updating the device?
Maybe I am misunderstanding things (still wet behind the ears with esphome) is there a way to flash the atom lite with the base ESPhome image outside of the linked wab page so that I can build upon it to manually add bluetooth (or other sensors if desired)
I confirm the confusion for the user! I have a new M5stack I wanted to quickly configure using the ready-made projects, and found that the M5Stack lite was removed from the BT proxy list.
Yes, but the layman could possibly be confused and there is an existing perfect configuration for that device. Why use a generic template when there is one specifically made for it?
