Machine Learning
F.ex the ability to show the most manually triggered scenes in an own card and maybe surface them based on time of day they are most used. This can also be used to help you create new automations based on your behaviour.
Check this out: http://scikit-learn.org/stable/
This could be useful for thermostats (such as Radio Thermostat CT80) that do not have learning capabilities compared to Nest. Let Home Assistant be a learning machine for home automation, but if Nest is part of the home network, the learning functionality can be disabled only for thermostat category so that Nest can handle it in it’s own.
Will that work?
Sure! Depending on how HA will be used…
