Hello!
I’m having an issue updating Home Assistant to the latest version via macOS’s App Store - it fails with an error ““Home Assistant” could not be installed. Please try again later.”. Here’s what I see in install.log
Any suggestions?
macOS Big Sur 11.1 (20C69)
Home Assistant installed: 2021.1.1
Home Assistant update: 2021.2.2
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 system_installd[1447]: PackageKit: Adding client PKInstallDaemonClient pid=1351, uid=501 (/System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent)
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Adding client PKInstallDaemonClient pid=1351, uid=501 (/System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent)
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 appstoreagent[1351]: Current Path: /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 appstoreagent[1351]: PackageKit: Enqueuing install with default quality of service (utility)
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: ----- Begin stage -----
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: request=PKInstallRequest <1 packages, destination=/>
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: packages=(
"PKLeopardPackage <id=io.robbie.HomeAssistant, version=2021.2.2, url=file:///var/folders/ph/9g9db4814h77x_8414fbbcq80000gn/C/com.apple.appstoreagent/com.apple.appstore/91EF360C-1D83-4370-B8FE-B8F8AA8A122D/mzps5553597563463565987.pkg#io.robbie.HomeAssistant.pkg>"
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Set reponsibility for install to 1351
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Skipping stale sandbox at path /Library/InstallerSandboxes/.PKInstallSandboxManager/811D99F3-787B-4DF7-8BD6-2A43CD601C32.activeSandbox
2021-02-10 19:52:00-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Extracting file:///var/folders/ph/9g9db4814h77x_8414fbbcq80000gn/C/com.apple.appstoreagent/com.apple.appstore/91EF360C-1D83-4370-B8FE-B8F8AA8A122D/mzps5553597563463565987.pkg#io.robbie.HomeAssistant.pkg (destination=/Library/InstallerSandboxes/.PKInstallSandboxManager/DE8A75EC-43DC-46D3-A292-21392D687A78.activeSandbox/Root/Applications, uid=0)
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Applying atomic-update from bundle at Applications/Home Assistant.app
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Verifying code signature on /Library/InstallerSandboxes/.PKInstallSandboxManager/DE8A75EC-43DC-46D3-A292-21392D687A78.activeSandbox/Root/Applications/Home Assistant.app
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Code signature on /Library/InstallerSandboxes/.PKInstallSandboxManager/DE8A75EC-43DC-46D3-A292-21392D687A78.activeSandbox/Root/Applications/Home Assistant.app/Contents/MacOS/Home Assistant did not verify (bundle format unrecognized, invalid, or unsuitable)
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Cleared responsibility for install from 1351.
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=123 "The update was canceled because the application integrity could not be verified." UserInfo={NSURL=file:///var/folders/ph/9g9db4814h77x_8414fbbcq80000gn/C/com.apple.appstoreagent/com.apple.appstore/91EF360C-1D83-4370-B8FE-B8F8AA8A122D/mzps5553597563463565987.pkg#io.robbie.HomeAssistant.pkg, PKInstallPackageIdentifier=io.robbie.HomeAssistant, NSLocalizedDescription=The update was canceled because the application integrity could not be verified.} {
NSLocalizedDescription = "The update was canceled because the application integrity could not be verified.";
NSURL = "file:///var/folders/ph/9g9db4814h77x_8414fbbcq80000gn/C/com.apple.appstoreagent/com.apple.appstore/91EF360C-1D83-4370-B8FE-B8F8AA8A122D/mzps5553597563463565987.pkg#io.robbie.HomeAssistant.pkg";
PKInstallPackageIdentifier = "io.robbie.HomeAssistant";
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Running idle tasks
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Removing client PKInstallDaemonClient pid=1351, uid=501 (/System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent)
2021-02-10 19:52:01-08 Alans-MacBook-Pro-16 installd[1449]: PackageKit: Done with sandbox removals
