Magic Home LedFx Bridge for LedFX
just add code in terminal in Home Assistant change names and ip and port numbers to your own.
then goto apps install check for updates! then install
then add lights to ledfx
add device use type ddpPreformatted text
.e.g.
Kitchen Right
IP: 192.168.1.123 (ip of your home assistant).
Pixels: 1
Port: 4048
Kitchen Left
Pixels: 1
Port: 4049
Bedroom
Pixels: 1
Port: 4050
mkdir -p /addons/magic_home_ledfx
cat > /addons/magic_home_ledfx/config.yaml <<'EOF'
name: "Magic Home LedFx Bridge"
version: "1.0.0"
slug: "magic_home_ledfx"
description: "Bridge LedFx DDP effects to Magic Home warm-white lights"
startup: application
boot: auto
init: false
arch:
  - amd64
ports:
  4048/udp: 4048
  4049/udp: 4049
  4050/udp: 4050
ports_description:
  4048/udp: "Bedroom LedFx DDP"
  4049/udp: "Kitchen Right LedFx DDP"
  4050/udp: "Kitchen Left LedFx DDP"
options:
  bedroom_ip: "192.168.1.136"
  kitchen_right_ip: "192.168.1.231"
  kitchen_left_ip: "192.168.1.193"
  max_fps: 12
  min_change: 3
schema:
  bedroom_ip: str
  kitchen_right_ip: str
  kitchen_left_ip: str
  max_fps: "int(1,30)"
  min_change: "int(0,50)"
EOF
cat > /addons/magic_home_ledfx/Dockerfile <<'EOF'
FROM ghcr.io/home-assistant/base:latest
ARG BUILD_VERSION
ARG BUILD_ARCH
LABEL \
  io.hass.version="${BUILD_VERSION}" \
  io.hass.type="app" \
  io.hass.arch="${BUILD_ARCH}"
RUN apk add --no-cache \
    python3 \
    py3-pip \
    py3-virtualenv \
  && python3 -m venv /opt/venv \
  && /opt/venv/bin/pip install --no-cache-dir flux_led
WORKDIR /app
COPY magic_home_ledfx.py /app/magic_home_ledfx.py
CMD ["/opt/venv/bin/python", "-u", "/app/magic_home_ledfx.py"]
EOF
cat > /addons/magic_home_ledfx/magic_home_ledfx.py <<'EOF'
import json
import socket
import threading
import time
from flux_led.device import WifiLedBulb
CONFIG_PATH = "/data/options.json"
def load_options():
    with open(CONFIG_PATH, "r", encoding="utf-8") as f:
        return json.load(f)
OPTIONS = load_options()
MAX_FPS = int(OPTIONS.get("max_fps", 12))
MIN_CHANGE = int(OPTIONS.get("min_change", 3))
LIGHTS = {
    4048: ("Bedroom", OPTIONS["bedroom_ip"]),
    4049: ("Kitchen Right", OPTIONS["kitchen_right_ip"]),
    4050: ("Kitchen Left", OPTIONS["kitchen_left_ip"]),
def run_light(port, name, ip):
    udp = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    udp.bind(("0.0.0.0", port))
    bulb = None
    last_level = -1
    last_send = 0.0
    powered_for_session = False
    print(
        f"{name}: listening for LedFx DDP on UDP {port} -> {ip}",
        flush=True,
    while True:
        packet, _ = udp.recvfrom(2048)
        # LedFx DDP header = 10 bytes.
        # RGB pixel data begins at byte 10.
        if len(packet) < 13:
            continue
        payload = packet[10:]
        if len(payload) < 3:
            continue
        r, g, b = payload[0:3]
        # These Magic Home controllers are warm-white only.
        # Convert LedFx RGB output into brightness.
        level = max(r, g, b)
        now = time.monotonic()
        # Limit update speed so we don't overload
        # the Magic Home Wi-Fi controller.
        if now - last_send < (1 / MAX_FPS):
            continue
        if last_level >= 0 and abs(level - last_level) < MIN_CHANGE:
            continue
        try:
            if bulb is None:
                bulb = WifiLedBulb(ip)
            if not powered_for_session:
                bulb.turnOn()
                powered_for_session = True
            bulb.setWarmWhite255(
                level,
                persist=False,
                retry=0,
            last_level = level
            last_send = now
        except Exception as err:
            print(
                f"{name}: controller error: {err}; reconnecting",
                flush=True,
            try:
                if bulb is not None:
                    bulb.close()
            except Exception:
                pass
            bulb = None
            time.sleep(0.25)
def main():
    print("Magic Home LedFx Bridge starting", flush=True)
    print(
        f"Maximum rate: {MAX_FPS} FPS | "
        f"Minimum brightness change: {MIN_CHANGE}",
        flush=True,
    for port, (name, ip) in LIGHTS.items():
        thread = threading.Thread(
            target=run_light,
            args=(port, name, ip),
            daemon=True,
        thread.start()
    while True:
        time.sleep(3600)
if __name__ == "__main__":
    main()
EOF
echo "Magic Home LedFx add-on files created."
