Magic Home-Tasmota configuration on Home Assistant
Hi, i have a magic Home Led controller RGB, not RGBW, with tasmota firmware installed, but
I don’t know how to integrate it into a home assistant. Could someone write me the code for Home Assistant?
Thank you
- platform: mqtt
    command_topic: "cmnd/garageled/POWER"
    state_topic: "stat/garageled/RESULT"
    state_value_template: "{{value_json.POWER}}"
    availability_topic: "tele/garageled/LWT"
    brightness_command_topic: "cmnd/garageled/Dimmer"
    brightness_state_topic: "stat/garageled/RESULT"
    brightness_scale: 100
    on_command_type: "brightness"
    brightness_value_template: "{{value_json.Dimmer}}"
    white_value_state_topic: "stat/garageled/RESULT"
    white_value_command_topic: "cmnd/garageled/Channel4"
    white_value_scale: 100
    white_value_template: "{{ value_json.Channel[3] }}"
    rgb_command_topic: "cmnd/garageled/Color2"
    rgb_state_topic: "stat/garageled/RESULT"
    rgb_value_template: "{{value_json.Color.split(',')[0:3]|join(',')}}"
    effect_command_topic: "cmnd/garageled/Scheme"
    effect_state_topic: "stat/garageled/RESULT"
    effect_value_template: "{{value_json.Scheme}}"
    effect_list:
      - 0
      - 1
      - 2
      - 3
      - 4
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    qos: 1
    retain: false
