Unless I’m not understanding if using the UI why can’t you simply add an entities or glance card and populate it with the entities you want? That’s pretty much what I have done. Create an entities card and choose the entities you want to see.
I believe for some reason Home Assistant triggers a state change even if the change is only an attribute. This would trigger the automation.
I am going to be looking into doing a trigger with trigger.from_state
to see if that helps. I’ll post anything that pans out.
Seems that a time pattern check could work although I’ve not received any iOS push notifications in the past 24 hrs but do see in the logs that the mail and packages is updating every 15 minutes. I don’t have any deliveries in transit either.
# NOTIFY IF MAIL IS EXPECTED
- alias: "Mail Notify - Mail Deliveries"
initial_state: 'on'
- platform: time_pattern
hours: /2 # repeat every 2 hrs.
- platform: state # Trigger if mail or packages get updated
entity_id: sensor.mail_usps_mail
- platform: state
entity_id: sensor.mail_usps_delivering
condition:
condition: and
conditions:
- condition: time # Time condition between 7AM - 9PM
after: '07:00:00'
before: '21:00:00'
- condition: or # Send only if mail or packages are more than 0
conditions:
- condition: template
value_template: "{{ states('sensor.mail_usps_mail') | int > 0 }}"
value_template: "{{ states('sensor.mail_usps_delivering') | int > 0 }}"
Hoping that someone can help with the image generation. I feel like it’s almost there but there’s just something misconfigured somewhere. I’m running HASS on Windows. The HASS directory is ....\.homeassistant
The integration is at: \.homeassistant\custom_components\mail_and_packages
According to the log: INFO (SyncWorker_4) [custom_components.mail_and_packages.sensor] Mail image generated.
But I don’t see the images anywhere. In the integration the mail images path is set up as: /config/www/mail_and_packages/
. I was following the examples but do I need something different specifically for a Windows environment? The \.homeassistant\www\mail_and_packages
dir is currently empty.
Ta.
Your image directory will need to be .../.homeassistant/www/mail_and_packages
where the ...
is whatever the path is to your Home Assistant config.
Tremendous, thanks. That fixed it - I didn’t realise it needed the full absolute path.
I am right in thinking that in order to display the image of today’s mail, you need to either:
- Use the custom Lovelace card and set it’s ‘
gif
’ property appropriately, OR - Define a camera pointing to a local file (and if using random gif names then have an automation that updates the local file name based on the mail sensor’s ‘
’ attribute).
For option 1, is the random image name feature supported? I tried setting ‘gif’ to something like:
/local/mail_and_packages/'{{ state_attr('sensor.mail_usps_mail','image') }}'
but that doesn’t work.
No worries. Checked the code - it’s not supported at the moment, so I’ll go the manual route for the UI.
I use the local_file camera and have an automation update the image when it changes, all my other entities are just in an entity card. Like so:
I do like his icons, think I’ll add them to my card
I really like the card that combines all the sensors as well as the gif so I’ve been trying to figure out how to add the amazon sensor to it.
Add a feature request to the card’s github?
Slimmed mine down now:
Oh i like that! Those icons are excellent
UPS, FedEx and the USPS are from the reddit post, I added in 2 amazon icons, one with black background, one with white (as shown).
Card config if you’d like as well:
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- entities:
- entity: sensor.mail_usps_mail
- entity: sensor.mail_packages_in_transit
name: Packages in Transit
- entity: sensor.mail_packages_delivered
name: Packages Delivered
- entity: sensor.mail_updated
- entity: input_select.notify_select
show_header_toggle: false
type: entities
- type: glance
entities:
- entity: sensor.mail_ups_packages
image: /local/icons/ups.png
- entity: sensor.mail_fedex_packages
image: /local/icons/fedex.jpeg
- entity: sensor.mail_usps_packages
image: /local/icons/usps.png
- entity: sensor.mail_amazon_packages
image: /local/icons/amazon-wh.png
show_name: false
Wow Thanks I will definitely be stealing some of that:)
Very nice - I as well have copied this setup. The icons are a very nice touch!
Thanks!
Credit to u/RUNNING_IN_SPACE
