I have my hands on a Mercator Ikuu single gang light switch as a test for my HA setup, which appears to use the Tuya TS0011 zigbee IC for control. I have a plan to use multiple of these ( single, dual, triple and quad gang) around the house.
I have this connected via Z2M and It’s possible to do some basic operations, ON, OFF, TOGGLE, Query State.
Unfortunately when I physically press the button on the light switch, it doesn’t push the state change, so the only way HA has to know if the light is ON or OFF is to query the switch’s state.
Ideally i would like to use the state change to trigger other events, turn on an exhaust fan, or a light further down the hallway etc and have them triggered instantly.
I want to avoid delays by querying the state of all my light switches multiple times a second clogging up the ZigBee network and slowing down the host PC running HA and Z2M.
Does anyone know of a wall switch (zigbee preferred) which pushes the switch state on physical button press?
or, is there some method of flashing the light switch’s micro-controller where i can more finely control the messages sent out from the wall switch ( esphome’esque type of flash )
Cheers!
