Major new feature release of the Weather Radar Card
Highlights
New: hazard overlays (US-only)
  • Wildfire perimeter overlay (show_wildfires: true) — active US wildfire perimeters from NIFC’s WFIGS Current Interagency Fire Perimeters feed. Active fires draw red, fully-contained ones grey. Small incidents render as a fire icon at the centroid; larger ones as a polygon outline. Click any fire for a popup with name, acreage, containment %, discovery date, and a link to NIFC’s InciWeb (gated against InciWeb’s RSS index so we don’t link to 404s). Adaptive 5/30-minute refresh. Filter knobs: wildfire_min_acres (default 10), wildfire_radius_km, plus colour / fill / refresh overrides.
  • NWS watches & warnings overlay (show_alerts: true) — active US National Weather Service watches and warnings from api.weather.gov/alerts/active, rendered as translucent polygons coloured per NWS’s standard warning palette. Both polygon-bearing and zone-based alerts render: zone shapes are fetched on-demand from api.weather.gov/zones/... and cached in localStorage (TTL 30 days) so they’re zero-network on subsequent sessions. Click any alert for a popup with event, headline, severity / certainty / urgency, effective and expiry windows, full description, and a link to weather.gov.
  • Hazard Overlays editor subpage — new top-level “Markers and Overlays” section groups the existing Markers list and the new Hazard Overlays subpage, which exposes per-overlay knobs and a 2-column grid of NWS alert-category checkboxes.
  • Region warnings — banner when any US-only feature is enabled with hass.config.country !== 'US' (multiple US-only features collapse into a single combined banner). New: separate banner for DWD selected outside its coverage (Germany + immediate neighbours: NL, BE, LU, FR, CH, AT, CZ, PL, DK), replacing the developer-facing one-shot console.warn from 3.4.0 with a visible UI cue.
Time-range editor (replaces frame_count)
  • past_minutes / forecast_minutes — source-agnostic time-range fields. Editor offers preset dropdowns filtered by per-source caps: RainViewer and NOAA show 20 / 40 / 60 / 120 min (cap 2 h); DWD shows up to 12 h. YAML can reach the API cap (DWD: 84 h, paired with frame_stride_minutes).
  • Forecast Duration field appears only on sources with a forecast (currently DWD: Off / 1 h / 2 h); hidden in the DOM otherwise.
  • frame_stride_minutes — YAML-only escape hatch for very large past windows on DWD.
  • SOURCE_CAPS table in src/source-caps.ts — single source of truth for per-source intervals, caps, and defaults.
  • Auto-migration — legacy frame_count and dwd_forecast_hours silently convert on load; existing configs need no changes.
Animation polish
  • smooth_overlap (0–1) — tunable crossfade overlap when smooth_animation: true. Sequential (no brightness dip) at 0, fully simultaneous (default; brief mid-transition dip) at 1. Editor exposes a slider with mutual gating against transition_time.
  • Trail-on-first-cycle and editor-open detection races fixed.
Quality-of-life — three contributions from @genericJE
  • Loading spinner in the bottom bar while tiles are fetching (#124).
  • “Now” marker on the progress bar — useful when DWD forecast frames push “now” away from the rightmost edge (#125).
  • Dark / satellite map scale text-shadow fix (#123).
Other notable changes
  • WYSIWYG map editing — pan/zoom in the live map auto-propagates to the editor’s Lat/Long/Zoom fields. The “Save as map center” button is gone.
  • Card-picker preview — static preview image in HA’s card-add picker.
  • Sections-grid supportgetGridOptions() plus a flex layout that fills any cell, with a responsive bottom row that hides the date prefix on narrow cards.
  • Pause when hidden — wildfire and NWS-alerts layers stop their refresh timers when the card is off-screen or the tab is hidden, refetching on resume if stale.
  • Dynamic radar tile size — picks 256 / 512 / 1024 / 2048 from map.getSize() so panel-view / fullscreen maps load with bigger tiles (fewer requests for the same coverage).
  • Build timestamp in console signon — confirms a hard refresh actually loaded the new bundle.
Documentation
  • 495-line README split into a slim landing page plus focused docs under docs/ (Configuration, Data Sources, Hazard Overlays, Markers, Examples, Animation architecture).
  • docs/animation.md rewritten to match the actual two-slot + delayed-fade-out model.
  • New design docs for the wildfire and NWS-alerts overlays.
Localization
11 language files now at 100% key parity. Brand acronyms (NWS, NOAA, NIFC) and the “Acres” US unit intentionally retained in source form.
Tests
128 → 268 unit tests (140 added).
Recent breaking changes
No breaking changes in 3.5.0. frame_count and dwd_forecast_hours are deprecated (auto-migrated, deprecation warning logged) but continue to work.
For context on prior breaking changes, see the 3.1.0 (multi-marker overhaul) and 3.0.0 (Leaflet bundled, iframe removed, native LitElement) entries in the CHANGELOG.
Also planned updates in flight -
  • Adding real time lightening srikes if ther Blitzortung intergration is installed
  • Adding wind overlay
  • Per user / map layer visibility control
Anyting else you'd like to see?
wow! super cool! i love this! will give it a try; during weather events (approaching storms, snow, etc) would be awesome to have this show up full-screen on my bar display automatically. no more weather channel ads or flakey websites!
Since it's a card rather than an integration I can't push events or create entities you could use to automate display. :frowning:
That said 3.6.0 just shipped with real time lightning display from the Blitzortung intergration
