Make SlimProto able to handle multiple remote rpi
SlimProto integration look like it is able to handle only one remote rpi. Since i have a Rpi in pretty much every room of the house, it would be very usefull
to make it multi rpi compatible, unless im missing something. i very like the fact that squeezelite install as a systemd service on the remote ‘client’ rpi so than can still be multi use, unlike volumio setup wich is the OS :frowning: thank’s and good job!
Slimproto is not limited to one client. But it will get confused if you are also running LMS on your network.
And it gets more confused if you are running music assistant as well.
Thank’s nickrout for [quote=“nickrout, post:2, topic:856894, full:true”]
[/quot
Thank’s nockrout for your quick response, here’s the picture of the message i get !??
Yes but it will detect all instances of slim devices.
