Hi Guys,
Is there a way much like it can be done with a switch : https://www.home-assistant.io/components/light.switch/
to control media player as light?
Hi Guys,
What drugs are you on? (I want some)
create a template switch?
This is my entity for the media player : media_player.bedroom_tv
would you mind attach en example with my entity?
What are you trying to do?
i would like to Bedroom TV will show up like the Mibox, so i can control it like a light.
What do you mean “control it like a light”. Do you mean “turn it on and off”.
yes with blue switch at the right just like in the picture
You may want to look at the custom mini-media_player. It can turn your media player into a full blown jukebox or by selective hiding of buttons and controls, turn it into an on/off switch.
The link I provided has an example already.
You’ve not provided any code or what your tv brand/model is, so I’ll assume your bedroom tv is called media_player.bedroom_tv
that it can be switched on, and that it has a state of on/off
your template switch would therefore look like this:
switches:
skylight:
value_template: "{{ is_state('media_player.bedroom_tv', 'on') }}"
turn_on:
service: media_player.turn_on
entity_id: media_player.bedroom_tv
turn_off:
service: media_player.turn_off
If you want to manage volume (as brightness) :
light:
lights:
media_player_bedroom_tv_as_a_light:
level_template: "{{ (256 * state_attr('media_player.bedroom_tv', 'volume_level')| float )|int }}"
turn_on:
turn_off:
set_level :
service: media_player.volume_set
data_template:
volume_level: "{{ ( brightness /256 )| float }}"
I use this card for this:
Yes Dennis,
It’s good for lovelace, but Alexa don’t recognise media_player volume and recognise light brighness
