Make use of the LLM to allow fuzzy detection of variables in automations conversation trigger
I’m trying to create various automations to enhance the functionality of my assistant but sometimes it doesn’t understand it 100% correctly (or it might prepend the wake word) and usually the LLM figures it out but in this case with the variables it doesn’t work
alias: Voice Command - Temporary Device Control
description: Handles voice commands like 'turn on X for Y seconds'
variables:
  operation: "{% if \"turn on\" in trigger.sentence|lower %}on{% else %}off{% endif %}"
  device_name: "{{ trigger.slots.device | lower }}"
  duration_seconds: |-
    {% if trigger.slots.duration %}
      {% if "minute" in trigger.sentence %}
        {{ (trigger.slots.duration | int) * 60 }}
      {% elif "hour" in trigger.sentence %}
        {{ (trigger.slots.duration | int) * 3600 }}
      {% else %}
        {{ trigger.slots.duration | int }}
      {% endif %}
    {% else %}
      {{ (trigger.slots.duration_hours | default(0) | int) * 3600 +
         (trigger.slots.duration_minutes | default(0) | int) * 60 +
         (trigger.slots.duration_seconds | default(0) | int) }}
    {% endif %}
mode: parallel
triggers:
  - command: turn on {device} for {duration} seconds
    trigger: conversation
  - command: turn off {device} for {duration} seconds
  - command: turn on {device} for {duration} minutes
  - command: turn off {device} for {duration} minutes
  - command: turn on {device} for {duration} hours
  - command: turn off {device} for {duration} hours
  - command: turn on {device} for {duration_hours} hours {duration_minutes} minutes
  - command: turn off {device} for {duration_hours} hours {duration_minutes} minutes
  - command: turn on {device} for {duration_minutes} minutes {duration_seconds} seconds
  - command: >-
      turn off {device} for {duration_minutes} minutes {duration_seconds}
      seconds
conditions:
  - condition: template
    value_template: "{{ duration_seconds > 0 }}"
actions:
  - variables:
      allowed_domains: "[\"light\", \"switch\", \"fan\", \"media_player\", \"cover\", \"climate\"]"
      excluded_entities: >-
        ["light.cob_strip_light_segment_001",
        "light.cob_strip_light_segment_002",
         "light.cob_strip_light_segment_003", "light.cob_strip_light_segment_004",
         "light.cob_strip_light_segment_005", "light.cob_strip_light_segment_006",
         "light.cob_strip_light_segment_007", "light.cob_strip_light_segment_008",
         "light.cob_strip_light_segment_009", "light.cob_strip_light_segment_010",
         "light.cob_strip_light_segment_011", "light.cob_strip_light_segment_012",
         "light.cob_strip_light_segment_013", "light.cob_strip_light_segment_014",
         "light.cob_strip_light_segment_015", "light.cob_strip_light_ble",
         "sensor.cob_strip_light_status", "button.cob_strip_light_request_platform_api_state",
         "switch.cob_strip_light_power_switch", "switch.cob_strip_light_gradient_toggle",
         "switch.cob_strip_light_dream_view_toggle"]
      entities: >-
        {% set found_entities = namespace() %} {% set found_entities.list = []
        %} {% set exact_match = namespace() %} {% set exact_match.entity = None
        %} {% for entity_id in states | map(attribute='entity_id') %}
          {% set domain = entity_id.split('.')[0] %}
          {% if domain in allowed_domains | from_json and entity_id not in excluded_entities | from_json %}
            {% set entity_name = state_attr(entity_id, 'friendly_name') | lower | default(entity_id.split('.')[-1].replace('_', ' '), true) %}
            {% if device_name == entity_name %}
              {% set exact_match.entity = entity_id %}
              {% break %}
            {% elif device_name in entity_name %}
              {% set found_entities.list = found_entities.list + [entity_id] %}
            {% endif %}
          {% endif %}
        {% endfor %} {% if exact_match.entity is not none %}
          ["{{ exact_match.entity }}"]
        {% else %}
          {{ found_entities.list | tojson }}
        {% endif %}
  - choose:
      - conditions:
            value_template: |-
              {% if entities is string %}
                {{ (entities | from_json) | count == 0 }}
              {% else %}
                {{ entities | count == 0 }}
              {% endif %}
        sequence:
          - data:
              message: Sorry, I couldn't find a device called {{ device_name }}.
              entity_id: assist_satellite.esp32_s3_box_3_assist_satellite
            action: assist_satellite.announce
      - conditions:
            value_template: |-
                {{ (entities | from_json) | count == 1 }}
              {% else %}
                {{ entities | count == 1 }}
              {% endif %}
        sequence:
          - parallel:
              - data:
                  message: >-
                    Turning {{ operation }} {{ device_name }} for {% if
                    duration_seconds // 3600 > 0 %}{{ (duration_seconds // 3600)
                    | int }}{% if duration_seconds // 3600 > 0 %} hours{% endif
                    %}{% endif %}{% if (duration_seconds % 3600) // 60 > 0 %}{%
                    if duration_seconds // 3600 > 0 %} and {% endif %}{{
                    ((duration_seconds % 3600) // 60) | int }} minutes{% endif
                    %}{% if duration_seconds % 60 > 0 %}{% if (duration_seconds
                    % 3600) // 60 > 0 or duration_seconds // 3600 > 0 %} and {%
                    endif %}{{ (duration_seconds % 60) | int }} seconds{% endif
              - data:
                  device_entity: |-
                      {{ (entities | from_json)[0] }}
                    {% else %}
                      {{ entities[0] }}
                    {% endif %}
                  operation: "{{ operation }}"
                  duration: "{{ duration_seconds }}"
                action: script.temporary_device_control
      - conditions:
            value_template: |-
                {{ (entities | from_json) | count > 1 }}
              {% else %}
                {{ entities | count > 1 }}
              {% endif %}
        sequence:
          - data:
              message: >-
                I found multiple devices matching {{ device_name }}. Please be
                more specific. Options are: {% if entities is string %}{% for
                entity_id in entities | from_json %}{{ state_attr(entity_id,
                'friendly_name') | default(entity_id.split('.')[-1].replace('_',
                ' '), true) }}{% if not loop.last %}, {% endif %}{% endfor %}{%
                else %}{% for entity_id in entities %}{{ state_attr(entity_id,
                endif %}
    default: []
