Making a Pi4 more robust as a HA hub?
I desperately need to get a home automation hub but I need to keep costs down. I thought getting a Pi4 with Home Assistant is a reasonable way forward but I heard that the reliability of MicroSD cards is not great. I’ve had a Pi2 running Kodi media player for several years which hasn’t had an issue so I don’t think it can be that bad. However, a home automation hub is a little more critical than the media player (my other family members may disagree with this though).
If I stick with the Pi4 (attached to a UPS), then what’s a reasonable way to improve the situation giving best bang for buck:
  1. Accept that it will eventually fail and take regular back ups so that I can easily restore onto a fresh SD card to get back up and running ASAP.
  2. Same as 1 but use a high endurance Micro SD card that’s designed for dashcams (e.g. the SanDisk High Endurance card)
  3. Use an SSD instead of a Micro SD card
Thoughts?
Go the SSD route. I have a 120GB SSD running HASSOS and it’s rock solid, even with 90 days full data retention for my database.
I run an external drive via the USB port, but if you wanted to spoil yourself get an Argon ONE M.2 case…
SSD: way more reliable and faster … but more expensive…
Here is a benchmark
Pi3B+ using an USB pen drive (“stick”) is a cheap alternative. I had some failures with SD cards, but never with USB pen drives. 3B+ is able to boot from USB out-of-the-box.
So will HASSOS and everything related to HA install directly on the SSD or will I need the Micro SD card in addition as well as the SDD? I had a look at the Argon One M2 case and it does look very very neat.
You need a small SD card to tell the pi to read from the USB instead of the SD card.
I would also say SSD.
SD cards and USB drives are not as reliable.
The SSD I bought was about the same price as a SD card.
128 GB for about $25-30.
I am running a Pi4 with an SSD and it is rock solid. I have had no issues after 6+ months, running complex Node-Red flows, a mix of WiFi and ZigBee devices.
Weird. I do not need that with my Pi 3B+ It boots directly off the USB connected SSD.
Probably because you used an SD card to tell it to do so.
After it’s done you don’t need the SD card anymore
That is true.
You just need to update the firmware - depending on the age of your rPi 4 this may already be done.
Once you have done that - treat the SSD just like you would a SD card. Load the image file to the SSD and boot from the SSD, make sure you have no SD card loaded.
It will:
  • Take slightly longer to do the drive expansion on first boot
  • Use more power. I use a genuine rPi4 power supply for mine and it is fine.
