Hello, I have a Fibaro metered wall plug switch, it reports watt and kWh and I can see the actual values.
However from my understanding kWh is the total it have ever consumed through the plug. If I want to brake it down to kWh/day to get a graph is there any good way todo that? I guess I could make an “algorithm” to calculate it from the meassured power, just checking if there are any standard way todo this in hass.
I’ve done this by creating a new helper Entity to capture the kWh from your source and set it to reset daily. This way you get a graph showing kWh today. Is that what you are looking for?
That’s it @Neil_Brownlee. Sorry forgot to say Utility meter in my post.
Give it a go, you can always delete it and try again. I’ve used them to great effect to capture daily readings.
