Beware a brand new user here. Using search has not resolved my issue. So his might be a dumb question but why is HA os native on a NUC so hard to use for first time users. May be LINUX nerds can navigate with ease but in these days one should be able to plug and play. Yes there is Terrific group support and such but it seems finicky. I am used to Windows, Mac os and Google home and Tuya and they all seem so much easier to get around. One example is using my NTFS portable drive with video content so I can plug it into my windows environment or HA and use Plex server on HA. BTW which I still have not got working. Surely AI might help. Or the OS that for example automatically detects and allows USB devices (non ext4) plugged into it...much like Windows or Mac os. IE; taking care of teh hardware environment. Is there a GUI front end? I am still looking but a very newby so be kind please.
Welcome. It would be helpful if you better described the actual problem you're trying to solve. General complaints and snarky comments about LINUX nerds generally won't lead to helpful replies. Check this out, then maybe try again....
HA is designed to minimize hardware requirements. Storage(to include media) is mostly network based. This can include local storage devices.
Review this Common tasks - Home Assistant Operating System - Home Assistant
Go to Settings/Systems/Storage to start with an external storage GUI
You will have to talk to Microsoft about that one.
NTFS is a proprietary protocol, so what you see in other OSes are reverse engineered integrations.
The security part often cause issues, because the security roles are defined in Windows and when you use a removable drive in Windows and move the drive to another OS, even another Windows, then those roles are not following along.
It probably has something to do with the fact that first time users often have little-to-no experience setting up a headless linux server or using containerized applications.
No, the OS does not have a GUI. For most users. once it's up and running, there is seldom any reason to interact directly with the OS. You can login to HA from any browser on your network or the mobile companion app.
Help with what?
To provide accurate responses, LLM bullshit engines need a large, relatively-homogeneous, corpus of data. The corpus of data about installing HAOS should be relatively-homogeneous since it hasn't changed much in the past few years, but it's also quite small compared to the corpus of data out there about installing other operating systems.
Hi, welcome to the forum!
It might seem to be hard depending on your overall experience with computers and the like.
It's based on Linux so some degree of knowledge is required but reading/following the documentation will help and most likely get you a running HA.
You could use AI if you're not willing to search/read but be aware that you might get wrong/outdated info.
The reason the systems that you mention are easier is because those are 'limited', ready to use.
Most likely you will have to dig a little deeper and invest some time to get some understanding of how HA works since the learning curve can be steep.
The return is a powerful home automation system that is second to none because of the versatility and privacy.
If you don't have the time to invest you're better off with something else.
BTW: immediately jumping on Plex is understandable but IMHO the wrong way around before getting familiar with HA.
And yes, this is a very helpful community for getting you started given that you do some effort yourself and respect some basic rules, therefor make sure you check How to help us help you - or How to ask a good question
Haffun!
Ok I think I have got on top of things. It is not that hard after all. I now have working Samba (mapped drive on my Notebook) and running PLex and it runs really well. My problem wa sI used AI to help me set up NTFS usb drives and it sent me down rabbit holes that eventually crashed my HA. Rebuilt from scratch, added internal second larger HDD in the box and all was sweet. Thanks for the support folks. Greatly appreciated.
