I live in an apartment built in the 1950’s with a garage door opener that is probably not much newer but is at least 20 years old. The only part number I can see on it is “132B2278” which does not come up in any database I can find but it has “Chamberlain Whisper Drive” written on the front and back.
There are some limiting factors:
- I rent so whatever I do has to be simple and easy to remove in such a way that my landlord (who never comes here) can’t complain.
- I don’t have easy access to the actual garage door drive itself. There is always a car parked under it (not mine) so anything I do has to happen somewhere else.
- I have easy access to the wall trigger (which has black, red, and white wires) but it has no power near it so if I can’t take power from it (my guess is no?) whatever I do needs battery power or be fully remote (there are outlets in the general area).
- It’s a shared garage; whatever I do can’t negatively impact my neighbors. They are lovely people.
- I don’t have a Zigbee or Matter network, let alone one that would reach this part of the building.
Things going for me:
- I have a stable and strong 2.4 Ghz WiFi signal down there.
- HA is up and running, has been for years, with all sorts of fun stuff going on. This is the part I’m comfortable with, but the hardware not so much.
Not a lot, I know… I did do some searching and saw the Ratgdo32 but that (a) seems to require a power source and (b) seems to want to be plugged into the drive unit itself so I think that’s a no-go?
What I was hoping was that the wall control basically just completes a circuit when you click a button. If that’s the case could I not just wire something inline that would also complete the circuit if triggered? Otherwise I was wondering if there’s a way to wire up a dummy remote somewhere in the basement that wirelessly triggers the garage door.
I’m sure people have done some version of what I’m hoping to do. Any suggestions, links to good examples of people doing this, etc? This is my first real DIY Home Assistant project so a little extra hand holding on this one would be appreciated. Once I have the hardware figured out I’m sure I can set it up in HA.
[Edit 1]
Been doing my own research as best I can and it seems like I might be able to use a Shelly 1 Gen4? As far as I can tell since I’m using an older 2-button garage door (looks a lot like this guy) what I’m seeing online is that thing is fully powered by the drive unit and I might be able to just run the Shelly inline and it’ll be powered? Maybe? I’m not sure how that wiring would work. I was thinking I could tap in with a few Posi Tabs (I need to check the gauge).
[Edit 2]
Good news bad news. I can reach one side of the garage door opener which let me get the model number: Chamberlain Whisper Drive WD822KS.
However, the other side is too far for me to reach just by hand and there’s no room to put a ladder. If my only option is to attach something to the garage door opener itself I’ll get my neighbors to move the car for an hour or two, I guess.
