I started making NodeRED nodes. Do you have some requests which you would like to see?
Maybe you can update the tuya local control node to use latest tuyapi library
I have only one problem. I don’t have any tuya device to test this but such a things should be tested as developed. This node uses version 3.2.3 but 5.0.0 is out and that is big update and lots of changes without real time testing.
Yeah I understand. Ive tried myself to update it couldn’t do it. Tuyapi docs said it was only necessary to pass the version in the constructor but didn’t work for me.
