Making picture-glance use the still image of camera
I’m using the camera_image parameter of the picture-glance lovelace card to show the my mjpeg camera. While I can click and see the live video as expected, the card itself when not clicked is shown as a broken link in most of the time. It seems to me that the still_image from mjpeg component is not being used.
So, is the picture-glance card really using the still image of the mjpeg component? If it can’t use the still_image, is there any way to avoid this broken links on UI?
can you provide an image of this ‘broken link’ you are referring to? Also, what component are you using for the camera?
My bad I think… I just realized this was happening only when accessing from work… Maybe it was a network issue on my side. Anyway, it seems to be working right now.
My work has a proxy which makes the camera load slowly, effectively making it useless when viewed on my work network. I’d wager you have the same issue.
