I’ve just started using Home Assistant in my house.
Right now I’ve flashed my sonoff bridge (pro) with tasmota and using several temperature/humidity sensors to closely watch my environment.
Right now we have basic Fränkische underfloor heating system with one control unit per room. It’s not easy to control heating system with this method. Also there is a actuator / per pipe (more than controller btw) in the
I want to change my heating management to something compatible with HA.
From what I see, there are several per-radiator wireless thermostatic valves in the market. But in my situation I need to change actuators in the manifolds.
Can anyone recommend a way to accomplish this project ?
I thought I can use radiator valves and command them through the values from temperature sensor values. But it won’t be easy.
