Good evening all,
I sure someone out there will be able to help me (again), i am trying to setup the manual alarm control panel with mqtt support to work with a rf keypad i have purchased. I have entered the config.yaml file as in the example but am having troubles getting the keypads commands to work with the frontend.
I have attached the config if you wouldn’t mind having a look for me that would be extremely appreciated.
alarm_control_panel:
- platform: manual_mqtt
state_topic: 'home/alarm'
command_topic: 'tele/RF_Bridge/RESULT'
qos: 1
value_template: '{{value_json.Data}}'
payload_disarm: "94C0C2"
payload_arm_home: "94C0C8"
payload_arm_away: "94C0C1"
code_template: "94C0C1 from_disarmed to_armed_away"
pending_time: 0
delay_time: 0
trigger_time: 4
disarmed:
trigger_time: 0
armed_home:
pending_time: 0
delay_time: 0
