First problem is all what i can press after upload firmware is “STOP” and if i click this i see button with name " Terminated process" There is no way to turn off this view beside pressing STOP
Second problem is i cannot integrate node and hassio, i tried to type “nodka1.local” but it is not working at all.Adn ofcourse nothing is detected automaticly
As you see in logs values are given, what i need to do to make it work like this version from old repo I just lost my patient to this.
Pressing the STOP button after everything is successfully uploaded and running is not a problem. You just exited the log viewer, and the node keeps working.
What happens if you ping to nodka1.local? Can you ping the node? Is your domain .local, or something else?
Can you try adding the node with its IP address? (I have no idea if that should work? @OttoWinter)
I again reinstall hassio to make it work, just in case. I just want to abandon this for this moment but if u answer i will give it next try
Probably mdns is not working on my router (i cannot open configuration by hassio.local) so that means i need to set static ip. But if i remember well, even if i set static ip for node, i saw her in connected devices to wifi but still the status was offline. I configured BME280 sensor and it shows his status in log but again, i wasnt able to integrate it. The offline status keeps remaining and that makes me sad and nervous, even if this work somehow
Ok now it is going to be strange I reinstalled hassio, create a node by this configurator, next i click edit and edit to sth like this
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: 'Nikola'
password: 'mynetpassword'
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.100.21
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.100.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
password: 'mypassword'
ota:
i2c:
sda: D6
scl: D7
scan: False
- platform: bme280
temperature:
name: "BME280 Temperature"
pressure:
name: "BME280 Pressure"
humidity:
name: "BME280 Humidity"
address: 0x76
update_interval: 60s
binary_sensor:
- platform: gpio
pin: D5
device_class: motion
- platform: gpio
pin: D0
And it integrate normally and shows Online status
Next i created another node with confige like this:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: 'Nikola'
manual_ip:
static_ip: 192.168.100.22
# Enable logging
logger:
api:
ota:
i2c:
sda: D2
scl: D1
scan: False
- platform: bme280
temperature:
pressure:
humidity:
address: 0x76
- platform: adc
pin: A0
name: "TEMT6000 Illuminance"
unit_of_measurement: lx
icon: "mdi:weather-sunny"
filters:
- lambda: |-
return (x / 10000.0) * 2000000.0;
output:
- platform: esp8266_pwm
pin: D6
pin: D5
pin: D0
light:
- platform: rgb
red: redgpio
green: greengpio
blue: bluegpio
#light_effects
effects:
- strobe:
name: Strobe Effect With Custom Values
colors:
- state: True
brightness: 100%
red: 100%
green: 90%
blue: 0%
duration: 500ms
- state: False
duration: 250ms
- state: True
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 500ms
- random:
name: Random Effect With Custom Values
transition_length: 2s
update_interval: 2s
- flicker:
name: Flicker Effect With Custom Values
alpha: 95%
intensity: 3.5%
And this one is showing offline status. I copied everything from first node and change ip only and add some info about sensors.
I dont know how to go thorugh this. Two almost the same configs and one is working well the next one is not. I am watching connected devices to my network. Differences between one wemos and naother is one have network adapcter comapny: Espressif Inc. and this working now has this blank.
Guys please help me im getting sick of this. I am running out of clues here.
EDIT: I deleted automatic intergate and restart hassio. after this i added manually nodes and they dont have any sensor inside. In esphome dashboard both are offline, but when i click show logs they showing actual status of sensors
I created a simple node as you proposed. There is a config:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: 'Nikola'
manual_ip:
static_ip: 192.168.100.28
# Enable logging
logger:
api:
ota:
- platform: wifi_signal
name: "WiFi Signal Sensor"
binary_sensor:
- platform: status
There is a upload by usb log. Before first line there was many “compiling” lines but i think they arent matter.
Compiling .pioenvs/test1/FrameworkArduino/umm_malloc/umm_malloc.c.o
Archiving .pioenvs/test1/libFrameworkArduino.a
Linking .pioenvs/test1/firmware.elf
Retrieving maximum program size .pioenvs/test1/firmware.elf
Building .pioenvs/test1/firmware.bin
Checking size .pioenvs/test1/firmware.elf
Memory Usage -> http://bit.ly/pio-memory-usage
DATA: [==== ] 39.5% (used 32344 bytes from 81920 bytes)
PROGRAM: [=== ] 31.2% (used 326392 bytes from 1044464 bytes)
======================== [SUCCESS] Took 260.88 seconds ========================
INFO Successfully compiled program.
INFO Connecting to 192.168.100.28
INFO Uploading /config/esphome/test1/.pioenvs/test1/firmware.bin (330544 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.100.28 using esphome API
INFO Connecting to 192.168.100.28:6053 (192.168.100.28)
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.100.28: timed out). Re-Trying in 1 seconds
INFO Successfully connected to 192.168.100.28
[13:43:13][I][application:098]: esphome-core version 1.11.2 compiled on Feb 28 2019, 13:38:58
[13:43:13][C][wifi:348]: WiFi:
[13:43:13][C][wifi:244]: SSID:
[redacted]
[13:43:13][C][wifi:245]: IP Address: 192.168.100.28
[13:43:13][C][wifi:247]: BSSID:
[redacted]
[13:43:13][C][wifi:248]: Hostname: 'test1'
[13:43:13][C][wifi:252]: Signal strength: -68 dB ▂▄▆█
[13:43:13][C][wifi:253]: Channel: 7
[13:43:13][C][wifi:254]: Subnet: 255.255.255.0
[13:43:13][C][wifi:255]: Gateway: 192.168.100.1
[13:43:13][C][wifi:256]: DNS1: 1.1.1.1
[13:43:13][C][wifi:257]: DNS2: 1.0.0.1
[13:43:13][C][binary_sensor.status:047]: Status Binary Sensor 'Test1 Status'
[13:43:13][C][binary_sensor.status:047]: Device Class: 'connectivity'
[13:43:13][C][logger:159]: Logger:
[13:43:13][C][logger:160]: Level: DEBUG
[13:43:13][C][logger:161]: Log Baud Rate: 115200
[13:43:13](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[13:43:13][C][sensor.wifi_signal:042]: WiFi Signal 'WiFi Signal Sensor'
[13:43:13][C][sensor.wifi_signal:042]: Unit of Measurement: 'dB'
[13:43:13][C][sensor.wifi_signal:042]: Accuracy Decimals: 0
[13:43:13][C][sensor.wifi_signal:042]: Icon: 'mdi:wifi'
[13:43:13][C][api:089]: API Server:
[13:43:13][C][api:090]: Address: 192.168.100.28:6053
[13:43:13][C][ota:129]: Over-The-Air Updates:
[13:43:13][C][ota:130]: Address: 192.168.100.28:8266
[13:43:13][C][ota:132]: Using Password.
After this status of node is still offline. They arent show automaticly in hassio but after manual integration sensors show up and it seems they are working, signal is -71 dB, status online (in hassio).
Router Huaiwei HG8247, everything in the same subnet.
Because mDNS is not working, it is showing offline in the ESPHome dashboard. Next release will make it possible to fallback to ‘normal’ ping connections. So next release you should be able to have them view as online.
You need to integrate them the way you did. So everything should be fine.
If you now add the other sensor (as in your previous config), they should show automatically. (because the node is added)
Please try adding the other sensors the same way, and let it know here if it worked.
Hello! Thanks for your answer and help.
I hope next release will show status correctly and i wont see any offline status.
As you writed, i manually added node, added sensors to config and they are visible and working in hassio. On the other node too.
So there left a problem with offline status but i hope it will be fixed soon
This is misunderstanding. As open ports i mean to give hassio server acces from outside (raspberry pi). I just thought mby esphome need acces to some port All devices are in one subnet
For this Problem in this thread there is a solution
ESPhome uses mDNS witch is a multicast protocol, multicast does not cross vlans.
You have 4 options:
Use a Firewall/Router that permits mDNS to cross vlans
Use Avahi reflector on a RPI connected to all vlans
On hass.io add the "status_use_ping=true"
On esphome docker dashboard use the env "ESPHOME_DASHBOARD_USE_PING=true"
