Hello, thank you. The tip was just right. I found the following automation. Maybe someone can help me figure out why it’s not working:
alias: BSC discovery
description: ""
triggers:
- alias: DataDevice
topic: bsc/DataDevice/+/+
enabled: true
trigger: mqtt
- topic: bsc/DataDevice/+/cellVoltage/#
enabled: true
trigger: mqtt
alias: Cell Voltages
- topic: bsc/DataDevice/+/temperature/#
enabled: true
trigger: mqtt
alias: DataDevice Temperatures
- alias: 1wire Temperature
topic: bsc/temperatur/#
enabled: true
trigger: mqtt
- alias: Inverter
topic: bsc/inverter/#
enabled: true
trigger: mqtt
- alias: Trigger
topic: bsc/trigger/#
enabled: true
trigger: mqtt
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
id:
- Inverter
sequence:
- action: mqtt.publish
qos: 0
topic: >-
homeassistant/sensor/{{ trigger.topic.split('/')[0]}}/{{
trigger.topic.split('/')[1]}}_{{
trigger.topic.split('/')[2]}}/config
retain: true
payload: |-
"name": "{{trigger.topic.split('/')[2]}}",
"state_topic": "{{ trigger.topic }}",
{% set d = { 'SoC': 'battery', 'chargeCurrentSoll': 'current', 'chargeVoltage': 'voltage', 'dischargeCurrentSoll': 'current', 'SoC': 'battery', 'temperature': 'temperature', 'totalCurrent': 'current', 'totalVoltage': 'voltage',} %}{% if d.get( trigger.topic.split('/')[2],'') %}"device_class":"{{ d.get( trigger.topic.split('/')[2]) }}",{% endif %}
"state_class": "measurement",
"unit_of_measurement": "{% set d = { 'chargeCurrentSoll': 'A', 'chargeVoltage': 'V', 'dischargeCurrentSoll': 'A', 'SoC': '%', 'temperature': '°C', 'totalCurrent': 'A', 'totalVoltage': 'V',} %}{{ d.get( trigger.topic.split('/')[2],'' ) }}",
"unique_id": "{{ trigger.topic.split('/')[0]}}_{{ trigger.topic.split('/')[1]}}_{{ trigger.topic.split('/')[2]}}",
"device": {
"identifiers": ["bsc_{{ trigger.topic.split('/')[0]}}"],
"name": "BSC",
"manufacturer": "BSC",
"model": "BSC",
"sw_version": "n/a",
"hw_version": "n/a",
"configuration_url": "https://github.com/dominikfe/ha_bsc_discovery_automation"
alias: Inverter
alias: Inverter
- conditions:
id:
- Trigger
sequence:
qos: 0
topic: >-
retain: true
payload: |-
"name": "Trigger {{trigger.topic.split('/')[2]}}",
"state_color": "true",
"device": {
"name": "BSC",
"model": "BSC",
alias: Inverter
alias: Trigger
- conditions:
id:
- DataDeviceTemperatures
sequence:
qos: 0
topic: >-
homeassistant/sensor/{{ trigger.topic.split('/')[0]}}{{
trigger.topic.split('/')[1]}}{{trigger.topic.split('/')[2]}}/{{trigger.topic.split('/')[3]}}{{trigger.topic.split('/')[4]}}/config
retain: true
payload: |-
"name": "Temperature Sensor {{ trigger.topic.split('/')[4]|int +1}}",
"device_class": "temperature",
"value_template": "{% raw %} {{ value }} {% endraw %}",
"unit_of_measurement": "°C",
"unique_id": "{{trigger.topic.split('/')[0]}}_{{trigger.topic.split('/')[1]}}_{{trigger.topic.split('/')[2]}}_{{trigger.topic.split('/')[3]}}_{{trigger.topic.split('/')[4]}}",
"device": {
"identifiers": ["{{trigger.topic.split('/')[0]}}_{{trigger.topic.split('/')[1]}}_{{trigger.topic.split('/')[2]}}"],
"name": "BSC {{trigger.topic.split('/')[1]}} {{trigger.topic.split('/')[2]}}",
"model": "BSC",
alias: Temperatures
alias: Temperatures
- conditions:
- condition: and
conditions:
- condition: template
value_template: "{{ trigger.payload != '0' }}"
id:
- CellVoltages
sequence:
qos: 0
topic: >-
trigger.topic.split('/')[0]}}{{trigger.topic.split('/')[1]}}{{trigger.topic.split('/')[2]}}/{{trigger.topic.split('/')[3]}}{{trigger.topic.split('/')[4]}}{{trigger.topic.split('/')[5]}}/config
retain: true
payload: |-
"name": "Cell {% if trigger.topic.split('/')[4]|int < 9 %}0{% else %}{% endif %}{{ trigger.topic.split('/')[4]|int +1}} Voltage",
"device_class": "voltage",
"value_templatee": "{% raw %} {{ value|int / 1000 }} {% endraw %}",
"dsp_prc": "4",
"unit_of_measurement": "V",
"unique_id": "{{ trigger.topic.split('/')[0]}}_{{ trigger.topic.split('/')[1]}}_{{ trigger.topic.split('/')[2]}}_{{trigger.topic.split('/')[3]}}{% if trigger.topic.split('/')[4]|int < 9 %}0{% else %}{% endif %}{{ trigger.topic.split('/')[4]|int +1}}",
"device": {
"model": "BSC",
alias: cellVoltages
alias: CellVoltages
- conditions:
value_template: >-
{{ trigger.topic.split('/')[3] != "cellVoltage" and
trigger.topic.split('/')[3] != "valid"}}
sequence:
qos: 0
topic: >-
trigger.topic.split('/')[0]}}{{trigger.topic.split('/')[1]}}{{trigger.topic.split('/')[2]}}/{{trigger.topic.split('/')[3]}}/config
retain: true
payload: |-
"name": "{{trigger.topic.split('/')[3]}}",
"state_topic": "{{ trigger.topic}}",
{% set d = { 'SoC': 'battery', 'balancingCurrent': 'current', 'cellVoltageMax': 'voltage', 'cellVoltageMin': 'voltage', 'cellVoltageMax': 'voltage', 'maxCellDifferenceVoltage': 'voltage', 'totalCurrent': 'current', 'totalVoltage': 'voltage'} %}{% if d.get( trigger.topic.split('/')[3],'') %}"device_class":"{{ d.get( trigger.topic.split('/')[3]) }}",{% endif %}
"unit_of_measurement": "{% set d = {'SoC': '%', 'balancingCurrent': 'A', 'cellVoltageMax': 'V', 'cellVoltageMin': 'V', 'cellVoltageMax': 'V', 'maxCellDifferenceVoltage': 'mV', 'totalCurrent': 'A', 'totalVoltage': 'V'} %}{{ d.get( trigger.topic.split('/')[3],'') }}",
"unique_id": "bsc_{{ trigger.topic.split('/')[2]}}_{{ trigger.topic.split('/')[3]}}",
"device": {
"model": "BSC",
alias: Rest
alias: Rest
mode: parallel
max: 10
