MrShannon
(Shannon Fritz)
March 15, 2025, 1:44am
103
It is possible to use this map-card to create something like a Geochron world map that shows the path of light/dark on the planet at a given time?
I would love to set some pins on the map that also shows the local time at that location as well, like this World Clock example
Here’s another example - Day and Night World Map
Johan_L
(Johan)
March 21, 2025, 2:01pm
104
Probably using the wrong config, but I would like to keep the map center on home coordinates and only adjust zoom level when enities are on the move.
focus_follow refocus & contains both move the card view, not only the zoom.
type: custom:map-card
tile_layer_url: https://basemaps.cartocdn.com/rastertiles/voyager/{z}/{x}/{y}.png
card_size: 24
zoom: 14
x: 51.5
"y": 4.9
entities:
- entity: person.johan
color: "#73C6B6"
- entity: person.2
color: "#FCD34D"
- entity: person.3
color: "#6FA3EF"
- entity: person.4
color: "#F9A8D4"
grid_options:
columns: full
nathan.gs
(Nathan)
March 22, 2025, 7:39pm
105
@Johan_L not possible at this time, can you create a ticket (and even better a pull request) on Github?
I’ve added this for my automower… Somehow, with Google or another one I tried (arcgisonline) the satellite images are completely washed out.
here’s my code :
entities:
- entity: device_tracker.mower
display: icon
icon: mdi:robot-mower-outline
color: grey
history_start: 24 hours ago
history_line_color: rgb(153,0,0)
tile_layer_url: https://mt0.google.com/vt/lyrs=s&x={x}&y={y}&z={z}
tile_layer_options:
attribution: Google Satellite
maxZoom: 19
minZoom: 0
And this is what I get :
If I chose roads, terrain or anything without satellite images, it looks normal. Is there a parameter I’m missing?
Thanks!
H.
Update for my issue…
I downgraded through HACS, starting with version 1.0.0 and… it worked, the map’s colours are no longer inverted (turns out they were not just washed out, but negative).
So I upgraded from there and it worked only until version 1.2.0. After that, I had a negative map. I still tried all subsequent versions, but no luck.
Here’s with version 1.2.0 :
Unfortunately, some options are not available 1.2.0.
Any Idea what changed then, and if it could be brought back?
Thanks.
H.
-Edit to add that I am now using Swisstopo satellite imagery, but it gives the same result with google satellite.
The next version after 1.2 introduces dark mode which is described as:
theme_mode: auto/dark/light can be configured.
Both map and icons swap to darkmode when mode is dark or auto & HA reports its theme is dark.
The theme_mode option is auto by default. Perhaps you should try:
theme_mode: light
When I try:
theme_mode: dark
my map looks like a negative similarly to the image in your previous post…
Rembock
April 26, 2025, 10:00pm
109
I’m using Card Mod to fix this issue:
card_mod:
style: |
ha-card #map.dark {
--map-filter: invert(0);
PlayedIn:
theme_mode: light
When I try:
theme_mode: dark
This is… strange?
But it works, thank you kind stranger!
@Rembock : I haven’t tried your solution as the other one seems to work with just one parameter. But thank you for your help.
carvalr
(Carvalr)
April 28, 2025, 7:02pm
111
I could not find a solution to my scenario, so please let me know if I have missed something.
I am trying to use this map card - amazing one, by the way - but I have an specific scenario where I have to use the config-template-card
to handle my entities name dynamically.
When using the card and the energy-date-selection
it works properly, but when adding then in a config-template-card
the history line stops working.
Is there anyway - except getting rid of config-template-card
- to make it work?
type: custom:config-template-card
entities:
- device_tracker.my_device
card:
type: grid
square: false
cards:
- type: custom:map-card
history_date_selection: true
entities:
- entity: device_tracker.my_device
card_mod:
style: |
ha-card {
margin-top: -10px;
ha-card #map {
height:calc(100vh - 56px);
border-radius:0;
- type: energy-date-selection
card_mod:
style: |
ha-card {
z-index: 1;
position: absolute;
height: 80px !important;
width: 80%;
top: 75px;
right: 10px;
max-width: 450px;
columns: 1
Left side: using config-template-card
Right side: not using config-template-card
CTC has no idea about a period defined in energy-date-selection.
Suggest to close the issue you opened in github.
Could be a FR for CTC…
carvalr
(Carvalr)
April 29, 2025, 12:54pm
113
The situation might not be related to the config-template-card itself.
Even when not using a energy-date-selection card but just “history_start” option, it doesn’t work as well.
So there is a compatibility issue between them related to the history line display.
entities:
card:
entities:
history_start: 30 hours ago
Very useful discovery. Please update the ticket in github for CTC. Will check it.
carvalr:
I am using custom:card-templater with the map-card with success. Have you tried it instead?
card-templater
Visible tiles are loaded (with a bit of a wider margin around), the heavy lifting is done by leaflet .
Johan_L
(Johan)
May 7, 2025, 10:00am
117
Is it possible to change the white background of the map marker icon to transparent?
And to remove the border of the icon?
I am using bits / pieces for my gtfs integration…
Vehicle positions vingerha/gtfs2 Wiki
Johan_L
(Johan)
May 8, 2025, 7:59am
120
Does this only work for seperate svg files or also when i use mdi: icons?
Dominicd
(HA-Dominicd)
May 16, 2025, 3:06pm
121
Thanks my friend: this work around worked for me too !
Tsar
(Christian)
May 18, 2025, 7:47pm
122
This is my configuration :
card_size: 12
zoom: 12
maxZoom: 20
focus_entity: device_tracker.gps_tracker_auto
follow_focus: refocus
entities:
- entity: device_tracker.gps_tracker_auto
color: purple
history_show_dots: false
gradual_opacity: 1.4
display: icon
history_line_color: purple
history_start: input_datetime.tijdstip_gps_tracker_start
history_end: input_datetime.tijdstip_gps_tracker_einde
Let say I did a selection of 2 days :
No problem, I get the history of these 2 days.
Now I change the start date to 5/18/2025 (so I only want the history of today). When I refresh my browser (F5), all the history disappears. I need to go to another dashboard (or edit the dashboard) to get my history back.
Is this normal and can I avoid that ? It would be nice if the map was updated automatically each time I change the period…
Are you sure you can use input_date helpers here? Is it described in docs?
