Map Card strange behaviour
I have been using the Map Card in Lovelace for several months now, and it works around 60% of the time, the other 40% of the time, the card does not display when I open the Lovelace view that contains it.
This happens when viewed on all devices that I have tried.
The really odd thing is that if I edit the card and change the aspect ratio, the card re-appears. It doesn’t seem to matter what I change it to, the card becomes visible again, but then subsequently stops appearing at a random point later.
Not sure if this is a widespread issue, or if it’s something to do with my configuration.
I am currently running on an Intel NUC
Home Assistant OS 8.0
Home Assistant Core 2202.5.5
Home Assistant Supervisor 2022.05.2
Kernel version 5.15.38
Agent Version 1.2.1
Though I had the same issue with earlier versions of HA, and when running on a Raspberry Pi.
The Map Card has two users and 5 zones and is set to use all Geolocation Sources. The users are tracked using the HA mobile app. with Geolocation Sensors enabled.
The map card is set to default zoom, showing 24 hours history and I have tried multiple aspect ratios.
I view Lovelace using Chrome on Windows and Android.
Can anyone shed any light on this issue?
There are issues on GitHub describing a “map card is not displayed” case, like:
  • if a right sidebar is shown (link);
  • if a custom:layout-card is used for the view (link);
  • if a custom:config-template-card is used (link).
