Map doesnt display any entities anymore?
Hi, not sure what happened, but seems on my map dashboard or map cards, my persons/zones/device tracker are gone, also the ones that are not home… they are just gone… any idea what can be the issue?
when i click on a person, i dont see it on map either, its defaulted back to “Amsterdam” …
Had a similar ‘surprise’ and after I cleaned a lot of cache from the browser it seemed to do the trick
EDIT: it is however quite interesting to see that Amsterdam is the heart of the world if everything else fails…no wonder the house prices re skyrocketing :slight_smile:
i cleaned cache too, i have it also in incognito on chrome, also on android companion app, after clearing cache too…
so my guess its not an cache issue
Well… those were my 2cts, am at 2025.3.1
So… returning on this as it is bugging me too now. Both yeterday and today I was paging through HA dashboards and suddenly all back to ‘amsterdam’, needed to restart the browser to get it OK again, refresh did not help but no cache delete needed this time.
It is a nuissance and I see that you already raised a ticket, not sure if this is in core though …might be ‘frontend’
It’s a strange issue indeed, glad that I’m not alone:+)
Do you think its a frontend issue? Did you create a ticket there?
I added to yours now, sadly the ‘bot’ made yours a person-integration thing instead of a map card issue, you may need to copy it to frontend
Ok, will create it there also, with map integration
