MAP: some MDIcons + pictures for device trackers not showing up
  1. I set up zones on the map in the config and gave them icons using the
    mdi:work
The problem is that only the “work” and “school” icons show up on my map.
The assigned names are no longer there visible I now see only zones and two above mentioned icons although I set 4 zones and 4 icons…
I2. also have a picture in the same folder as the configuration file and known devices file, and I can not get the figure to show up on the map… I only get a white circle with the assigned tracker name under it.
l2. also have a picture in the same folder as the configuration file and known devices file, and I can not get the figure to show up on the map… I only get a white circle with the assigned tracker name under it.
The frontend of Home Assistant is served with the help of a local web server. If you have customized your installation you already use this functionality. The content of your folder www in your Home Assistant configuration directory (.homeassistant) is available under /local (eg. https://localhost:8123/local).
Unsure about the rest.
