im searching for a solution to map the target temperature from the generic climate component to a service. I want to send the value to the modbus.write_register service.
Can someone help me out?
Documentation and feature set can change rapidly, so I may be wrong. But I don’t think you can have a “data” and a “data_template”. Just use “data_template” for everything if you have any values that need template features.
Otherwise, nothing is standing out as being wrong to me. Give that a shot and if it doesn’t work, be sure to post any errors shown in the logs.
