I guess at some level the map card is the same as the default one? Is it possible to turn off dark mode for the map (just like you can when adding it as a card) ?
I see this leads to a closed bug report then onto another closed bug report - is there any possibility of a system-wide fix because the workaround on Reddit does not fix the map within HA itself e.g. location/zone settings in Configuration.
Did you find any solution to this?
I like the dark mode on my HA but i need the built-in map to be light-mode. Can’s se squat on the map in dark mode when I’m outside in daylight.
