MariaDB 2.6.10 upgrade
My mariadb database upgrade takes a whole week now. I don’t see any progress. Just my sensors are not updated, which is fine for a couple of hours but this is a bit long.
I installed mariaDB 2.6.10 in the 2.5.2 addon. It is a 1.7Gb states table. Due to powerloss the system restarted yesterday and I got the notification the upgrade is busy and system performance is degraded. Which is fine, but how can I tell is isn’t stuck or hanging?
In the 2023.2.3, I believe, I had to drop the homeassistant database and import it back in. Which was in addon version 2.5.1. Due to indexes being corrupt. It worked fine afterwards and I still had all my data.
I read something about setting the logger level to info instead of the default warning level. This is something I didn’t do. And there are no log entries regarding the MariaDB.
EDIT:
MariaDB Log:
2023-02-20 22:50:52 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-02-20 22:50:52 0 [Note] Server socket created on IP: '::'.
2023-02-20 22:50:52 0 [Note] /usr/bin/mariadbd: ready for connections.
Version: '10.6.10-MariaDB'  socket: '/run/mysqld/mysqld.sock'  port: 3306  MariaDB Server
[22:50:53] INFO: Check data integrity and fix corruptions
mysql.column_stats                                 OK
mysql.columns_priv                                 OK
mysql.db                                           OK
mysql.event                                        OK
mysql.func                                         OK
mysql.global_priv                                  OK
mysql.gtid_slave_pos                               OK
mysql.help_category                                OK
mysql.help_keyword                                 OK
mysql.help_relation                                OK
mysql.help_topic                                   OK
mysql.index_stats                                  OK
mysql.innodb_index_stats                           OK
mysql.innodb_table_stats                           OK
mysql.plugin                                       OK
mysql.proc                                         OK
mysql.procs_priv                                   OK
mysql.proxies_priv                                 OK
mysql.roles_mapping                                OK
mysql.servers                                      OK
mysql.table_stats                                  OK
mysql.tables_priv                                  OK
mysql.time_zone                                    OK
mysql.time_zone_leap_second                        OK
mysql.time_zone_name                               OK
mysql.time_zone_transition                         OK
mysql.time_zone_transition_type                    OK
mysql.transaction_registry                         OK
nginxproxymanager.access_list                      OK
nginxproxymanager.access_list_auth                 OK
nginxproxymanager.access_list_client               OK
nginxproxymanager.audit_log                        OK
nginxproxymanager.auth                             OK
nginxproxymanager.certificate                      OK
nginxproxymanager.dead_host                        OK
nginxproxymanager.migrations                       OK
nginxproxymanager.migrations_lock                  OK
nginxproxymanager.proxy_host                       OK
nginxproxymanager.redirection_host                 OK
nginxproxymanager.setting                          OK
nginxproxymanager.stream                           OK
nginxproxymanager.user                             OK
nginxproxymanager.user_permission                  OK
phpmyadmin.pma__bookmark                           OK
phpmyadmin.pma__central_columns                    OK
phpmyadmin.pma__column_info                        OK
phpmyadmin.pma__designer_settings                  OK
phpmyadmin.pma__export_templates                   OK
phpmyadmin.pma__favorite                           OK
phpmyadmin.pma__history                            OK
phpmyadmin.pma__navigationhiding                   OK
phpmyadmin.pma__pdf_pages                          OK
phpmyadmin.pma__recent                             OK
phpmyadmin.pma__relation                           OK
phpmyadmin.pma__savedsearches                      OK
phpmyadmin.pma__table_coords                       OK
phpmyadmin.pma__table_info                         OK
phpmyadmin.pma__table_uiprefs                      OK
phpmyadmin.pma__tracking                           OK
phpmyadmin.pma__userconfig                         OK
phpmyadmin.pma__usergroups                         OK
phpmyadmin.pma__users                              OK
sys.sys_config                                     OK
[22:50:53] INFO: Ensuring internal database upgrades are performed
[22:50:53] INFO: Ensure databases exists
[22:50:54] INFO: Create database HomeAssistant
[22:50:54] INFO: Ensure users exists and are updated
[22:50:54] INFO: Update user homeass
[22:50:54] INFO: Init/Update rights
[22:50:54] INFO: Granting all privileges to homeass on HomeAssistant
[22:50:55] ERROR: Got unexpected response from the API: There is already a MySQL service in use from core_mariadb
[22:50:55] INFO: Successfully send service information to Home Assistant.
2023-02-21  5:44:04 27 [Warning] Aborted connection 27 to db: 'HomeAssistant' user: 'homeass' host: '172.30.XXX.XXX' (Got an error reading communication packets)
2023-02-21  5:44:04 31 [Warning] Aborted connection 31 to db: 'HomeAssistant' user: 'homeass' host: '172.30.XXX.XXX' (Got an error reading communication packets)
2023-02-21  5:44:04 33 [Warning] Aborted connection 33 to db: 'HomeAssistant' user: 'homeass' host: '172.30.XXX.XXX' (Got an error reading communication packets)
2023-02-21  5:44:04 26 [Warning] Aborted connection 26 to db: 'HomeAssistant' user: 'homeass' host: '172.30.XXX.XXX' (Got an error reading communication packets)
2023-02-21  7:24:45 28 [Warning] Aborted connection 28 to db: 'HomeAssistant' user: 'homeass' host: '192.168.XXX.XXX' (Got timeout reading communication packets)
Edit 2:
Some hardware info:
- Quad 'Core' Intel(R) Celeron(R) CPU  J1900
- 240 SATA SSD
- 4Gb Memory
Mem info:
               total        used        free      shared  buff/cache   available
Mem:            3638        1928         201           1        1508        1449
Swap:           7977         496        7481
Is there anything else I can do?
It’s still upgrading. Is there anything I can do? Or monitor the process somehow?
