I’ve been trying to track down a suspected memory leak. I’m running HA 0.99.3 on a Raspberry Pi 3 for about a year now without too much issue. Over the past couple of months I’ve noticed the memory usage getting close to 100%. The system becomes unresponsive and the only thing that resolves it is a hard reboot of the raspberry pi. Also, I’ve tried just a restart of HA but that doesn’t resolve it. It has to be a hard reset of the device.
I disabled all of my add-ons and slowly re-added one at a time and I’ve got it narrowed down to MariaDB. Over a period of 4-5 days the memory usage will steadily creep from about 40% after reboot, to 95%+ until a system reset is required. If I disable mariadb the memory stays steady at about 33% and doesn’t increase.
Anyone else having this issue with MariaDB and know how to fix it?
I’m using MariaDB on a synology NAS and don’t have the memory leak issue, but do fine it can use quite a lot of memory when caching in order to speed things up.
I’ve found keeping the DB size under 1GB helps a little.
In case anyone finds this, it wasn’t MariaDB that was causing the memory issue. It was influx. I was running MariaDB, influx and grafana. Grafana requires influx for it’s graphs. Every time I start up influx within a short amount of time it maxes out the memory. No influx, no memory creep.
