which works fine.
However, when sending commands, llke adding a passcode or setting a lock mode, it appears to send the command very quickly, and a second or two later, the lock has been updated. However, the entities in HA seem to take a long time to update. This might not be fixable as the delay might be on the ttlock server side.
So… I was thinking, how can I mask this problem. I know the entity has actually been updated (almost instantly), its just HA doesn’t know about it yet. I was thinking of maybe using an input boolean as I simply need to know whether the command has been done, or not done, and by changing the state of the boolean, just run an automation to do the ‘work’. I then track the state of the boolean on my dashboard, not the state of the entity itself.
It might be worth trying a call to homeassistant.update_entity to see if that causes it to update. The website says it uses a webhook to update, so you’d expect it to be fast, but I see there’s an outstanding issue where people are saying manually unlocking does not reflect in HA, which would suggest the webhook isn’t working properly.
