Today, I modified the integrations I use to import data from my solar inverter into home assistant.
As a result, a few of my entities jumped by what seems like a few megawatt-hours, resulting in the system thinking I used >$1000 of power in one day (or one hour) :
(Both the Power meter Consumption and Power meter Exported values are incorrect, everything else is OK) - at this stage, I'd be OK if both of them are reset to $0 for the day.
I managed to fix the entity itself by going into Developer Tools -> Statistics -> Adjust -> Outliers.
But this does not fix the incorrect value that's already been computed by home assistant for cost.
This is going to throw off my whole year's energy calculation - any way I can fix it? According to the ol' LLM the only way is to go poking around in the DB and while I don't mind rolling up my sleeves I'd rather save this optoin as a last resort if I can.
Classic. After searching on and off all day, I stumbled into this thread which lead me to the solution:
I went to Developer Tools -> Statistics and searched for "NZD" which threw up ~8 entities.
I went through to the Adjust option for each one and into Outliers and sure enough turned up those values as seen; I just put them to $0 (this represnets about 1.5 hr of lost data which is no big deal!) - so this is cured now.
