Thank you for your reply!
I am using a Google Pixel 7 running Android 17 (latest version) and Security Patch 5. Juli 26.
At the moment I am using a Telekom Speedport Smart 4. (hate that thin and going to change as soon as I can get out of my contract)
I did not find an easy way to attach the log files so i will copy paste them here.
Everything that happend today 23.07.2026 (DD.MM.YYYY) should tell the story. This morning i restartet HA and tried parring the Ikea Alpstuga again to create the logs.
OTBR Logs:
[21:54:33] INFO: e[32mThe otbr-web is disabled.e[0m
/run/s6/basedir/scripts/rc.init: info: hook /etc/s6-overlay/scripts/enable-check.sh exited 0
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
e[34m-----------------------------------------------------------e[0m
e[34m Add-on: OpenThread Border Routere[0m
e[34m OpenThread Border Router appe[0m
e[34m Add-on version: 3.0.2e[0m
e[32m You are running the latest version of this add-on.e[0m
e[34m System: Home Assistant OS 18.1 (amd64 / generic-x86-64)e[0m
e[34m Home Assistant Core: 2026.7.3e[0m
e[34m Home Assistant Supervisor: 2026.07.3e[0m
e[34m Please, share the above information when looking for helpe[0m
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
s6-rc: info: service banner successfully started
s6-rc: info: service otbr-agent: starting
[21:54:33] INFO: e[32mSetup OTBR firewall...e[0m
[21:54:33] INFO: e[32mMigrating OTBR settings if needed...e[0m
2026-07-22 21:54:34 homeassistant asyncio[232] DEBUG Using selector: EpollSelector
2026-07-22 21:54:34 homeassistant zigpy.serial[232] DEBUG Opening a serial connection to '/dev/serial/by-id/usb-SONOFF_SONOFF_Dongle_Plus_MG24_2c4efe797da3ef1194af4abd61ce3355-if00-port0' (baudrate=460800, xonxoff=False, rtscts=False)
2026-07-22 21:54:34 homeassistant serialx.platforms.serial_posix[232] DEBUG Locking serial port '/dev/serial/by-id/usb-SONOFF_SONOFF_Dongle_Plus_MG24_2c4efe797da3ef1194af4abd61ce3355-if00-port0'
2026-07-22 21:54:34 homeassistant serialx.platforms.serial_posix[232] DEBUG Configuring serial port '/dev/serial/by-id/usb-SONOFF_SONOFF_Dongle_Plus_MG24_2c4efe797da3ef1194af4abd61ce3355-if00-port0'
2026-07-22 21:54:34 homeassistant serialx.platforms.serial_posix[232] DEBUG Configuring serial port: TcsetattrFlags(iflag=0, oflag=0, cflag=3248, lflag=0, ispeed=4100, ospeed=4100, cc_vmin=0, cc_vtime=0) + cc=[b'\x03', b'\x1c', b'\x7f', b'\x15', b'\x04', 0, 0, b'\x00', b'\x11', b'\x13', b'\x1a', b'\x00', b'\x12', b'\x0f', b'\x17', b'\x16', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00']
2026-07-22 21:54:34 homeassistant serialx.platforms.serial_linux[232] DEBUG Setting low latency mode: True
2026-07-22 21:54:34 homeassistant serialx.platforms.serial_posix[232] DEBUG Setting modem pins: ModemPins[!dtr !rts]
2026-07-22 21:54:34 homeassistant serialx.platforms.serial_posix[232] DEBUG TIOCMBIC: 0x00000006
2026-07-22 21:54:34 homeassistant zigpy.serial[232] DEBUG Connection made: <serialx.platforms.serial_linux.LinuxSerialTransport object at 0x7f5e48075190>
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.RESET: 1>, data=b'\x02')
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Sending data b'~\x80\x01\x02\xea\xf0~'
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Immediately writing b'~\x80\x01\x02\xea\xf0~'
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Sent 7 of 7 bytes
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Event loop woke up reader
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Received b'~\x80\x06\x00p\xeet~'
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x80\x06\x00p')
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x00p')
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Immediately writing b'~\x83\x02\x08\xbc\x9a~'
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Received b'~\x83\x06\x08\x18\r\xf9\xff\xfe\xd2\x18\xcc\x8a\x08~'
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x83\x06\x08\x18\r\xf9\xff\xfe\xd2\x18\xcc')
2026-07-22 21:54:34 homeassistant universal_silabs_flasher.spinel[232] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x08\x18\r\xf9\xff\xfe\xd2\x18\xcc')
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Closing at the request of the application
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Backgrounding a close request: None
2026-07-22 21:54:34 homeassistant zigpy.serial[232] DEBUG Waiting for serial port to close
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Closing connection: None
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Closing file descriptor 7
2026-07-22 21:54:34 homeassistant serialx.descriptor_transport[232] DEBUG Calling protocol `connection_lost` with exc=None
2026-07-22 21:54:34 homeassistant zigpy.serial[232] DEBUG Connection lost: None
Adapter settings file /data/thread/0_180df9fffed218cc.data is the most recently used, skipping
[21:54:34] INFO: e[32mStarting otbr-agent...e[0m
[NOTE]-AGENT---: Running 0.3.0-624a7d98-dirty
[NOTE]-AGENT---: Thread version: 1.4.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/serial/by-id/usb-SONOFF_SONOFF_Dongle_Plus_MG24_2c4efe797da3ef1194af4abd61ce3355-if00-port0?uart-baudrate=460800&uart-init-deassert
[NOTE]-AGENT---: Radio URL: trel://enp1s0
[NOTE]-ILS-----: Infra link selected: enp1s0
49d.17:03:16.586 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.049 [N] BorderRouting-: BR ULA prefix: fd48:798:4e34::/48 (loaded)
00:00:00.049 [N] BorderRouting-: Local on-link prefix: fd67:a2e8:3abc:a3f0::/64
[WARN]-UTILS---: /usr/src/ot-br-posix/src/rest/network_diag_handler.cpp:1300 lacking some attributes for deviceId de91a3a9b8eeba03
[WARN]-UTILS---: /usr/src/ot-br-posix/src/rest/network_diag_handler.cpp:1244 cannot get LeaderData while detached
[WARN]-UTILS---: /usr/src/ot-br-posix/src/rest/rest_devices_coll.cpp:232 - AddItem - de91a3a9b8eeba03
00:00:00.067 [N] Mle-----------: Role disabled -> detached
00:00:00.067 [N] P-Netif-------: Changing interface state to up.
00:00:00.071 [W] P-Netif-------: Failed to process request#2: No such process
00:00:00.071 [W] P-Netif-------: Failed to process request#6: No such process
Connection to 172.30.32.1 8081 port [tcp/tproxy] succeeded!
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
Done
00:00:00.262 [W] P-Daemon------: Failed to write CLI output: Broken pipe
[21:54:34] INFO: e[32mSetting OpenThread mDNS local hostname to homeassistant-otbr.e[0m
Done
Done
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
[21:54:34] INFO: e[32mSuccessfully sent discovery information to Home Assistant.e[0m
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
00:00:27.557 [N] Mle-----------: RLOC16 4400 -> fffe
00:00:28.232 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:34.732 [N] RouterTable---: Allocate router id 17
00:00:34.732 [N] Mle-----------: RLOC16 fffe -> 4400
00:00:34.735 [N] Mle-----------: Role detached -> leader
00:00:34.735 [N] Mle-----------: Partition ID 0x3f965fa7
[NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
11:23:51.693 [N] RouterTable---: Allocate router id 16
Matter Server Logs:
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
e[34m Add-on: Matter Servere[0m
e[34m Matter WebSocket Server for Home Assistant Matter support.e[0m
e[34m Add-on version: 9.1.0e[0m
s6-rc: info: service matter-server: starting
s6-rc: info: service matter-server successfully started
[21:54:36] INFO: e[32mStarting Matter Server...e[0m
[21:54:36] INFO: e[32mTime sync 'auto': host NTP is not synchronized, leaving time sync disabled.e[0m
[21:54:36] INFO: e[32mUsing 'enp1s0' as primary network interface.e[0m
[21:54:36] INFO: e[32mSuccessfully send discovery information to Home Assistant.e[0m
e[2m2026-07-22 21:54:40.721 INFO e[0;1;90mMatterServer e[0mCommand line: --storage-path /data --port 5580 --log-level info --primary-interface enp1s0 --fabricid 2 --vendorid 4939 --listen-address 172.30.32.1 --listen-address 127.0.0.1e[0m
e[2m2026-07-22 21:54:40.729 INFO e[0;1;90mMatterServer e[0mUsing storage drivers: kv=wal, blob=dire[0m
e[2m2026-07-22 21:54:40.731 INFO e[0;1;90mConfigStorage e[0mStorage location: /data (Directory)e[0m
e[2m2026-07-22 21:54:40.739 INFO e[0;1;90mNodeJsDirectoryLock e[0mCleaning stale storage lock for config - PID 117 reused (token mismatch)e[0m
e[2m2026-07-22 21:54:40.757 INFO e[0;1;90mConfigStorage e[0mSet config key fabricLabel to Homee[0m
e[2m2026-07-22 21:54:40.763 INFO e[0;1;90mConfigStorage e[0mSet config key nextNodeId to 6e[0m
e[2m2026-07-22 21:54:40.765 INFO e[0;1;90mConfigStorage e[0mSet config key wifiSsid to YerAWiFiHarrye[0m
e[2m2026-07-22 21:54:40.766 INFO e[0;1;90mConfigStorage e[0mSet config key wifiCredentials to <redacted>e[0m
e[2m2026-07-22 21:54:40.768 INFO e[0;1;90mConfigStorage e[0mSet config key threadDataset to <redacted>e[0m
e[2m2026-07-22 21:54:40.770 INFO e[0;1;90mServerIdResolver e[0mFound existing storage for server ID: server-2-134be[0m
e[2m2026-07-22 21:54:40.773 INFO e[0;1;90mNodeJsDirectoryLock e[0mCleaning stale storage lock for server-2-134b - PID 117 reused (token mismatch)e[0m
e[2m2026-07-22 21:54:40.794 INFO e[0;1;90mDclCertifi~teService e[0mInitialize CertificateService e[34mprod: e[2;39mhttps://on.dcl.csa-iot.org e[0;34mtest: e[2;39mhttps://on.test-net.dcl.csa-iot.org e[0;34mgithub: e[2;39myese[0m
e[2m2026-07-22 21:54:40.797 INFO e[0;1;90mDclVendorInfoService e[0mInitialize VendorInfoService e[34msource: e[2;39mhttps://on.dcl.csa-iot.org e[0;34minterval: e[2;39m24he[0m
e[2m2026-07-22 21:54:40.798 INFO e[0;1;90mController~ndHandler e[0mBLE is disablede[0m
e[2m2026-07-22 21:54:40.802 NOTICE e[0;1;90mWebSocketC~erHandler e[0;32mStarting server: matter-server/1.2.6 (matter.js/0.17.6-alpha.0-20260715-3585d95fe)e[0m
e[2m2026-07-22 21:54:40.806 INFO e[0;1;90mNodeJsDirectoryLock e[0mCleaning stale storage lock for vendors - PID 117 reused (token mismatch)e[0m
e[2m2026-07-22 21:54:40.806 INFO e[0;1;90mNodeJsDirectoryLock e[0mCleaning stale storage lock for certificates - PID 117 reused (token mismatch)e[0m
e[2m2026-07-22 21:54:40.880 INFO e[0;1;90mDclCertifi~teService e[0mLoaded 179 certificates from storagee[0m
e[2m2026-07-22 21:54:40.931 INFO e[0;1;90mDclCertifi~teService e[0mseed: consumed 0 PAA certs from snapshot 2026-07-15T03:06:06.361Ze[0m
e[2m2026-07-22 21:54:40.937 INFO e[0;1;90mDclCertifi~teService e[0mseed: consumed 0 CDSigner certs from snapshot 2026-07-15T03:06:06.361Ze[0m
e[2m2026-07-22 21:54:40.959 INFO e[0;1;90mDclVendorInfoService e[0mLoaded 455 vendors from storagee[0m
e[2m2026-07-22 21:54:40.959 INFO e[0;1;90mDclVendorInfoService e[0mseed: skipping vendors — storage has 455 entries >= seed expectedCount 455e[0m
e[2m2026-07-22 21:54:40.959 INFO e[0;1;90mDclVendorInfoService e[0mFetching vendor information from DCLe[0m
e[2m2026-07-22 21:54:40.967 INFO e[0;1;90mServerNodeStore e[0mOpened e[1mserver-2-134b e[0mstorage e[34mlocation: e[2;39m/data/server-2-134b e[0;34mdriver: e[2;39mwale[0m
e[2m2026-07-22 21:54:41.080 INFO e[0;1;90mBaseEventStore e[0mLoaded volatile event store with next number 16001e[0m
e[2m2026-07-22 21:54:41.087 INFO e[0;1;90mEndpoint e[39mserver-2-134b e[0mready e[34mendpoint#: e[2;39m0 e[0;34mtype: e[2;39mRootNode (0x16, rev 4) e[0;34mbehaviors: e[90m💤parts e[32m✓index ✓accessControl ✓basicInformation ✓generalCommissioning ✓generalDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement ✓commissioning ✓network e[90m💤productDescription 💤subscriptions 💤sessions e[32m✓events e[90m💤controller e[32m✓descriptore[0m
e[2m2026-07-22 21:54:41.109 INFO e[0;1;90mDclOtaUpdateService e[0mInitialize OTAUpdateService e[34mprod: e[2;39mhttps://on.dcl.csa-iot.org e[0;34mtest: e[2;39mhttps://on.test-net.dcl.csa-iot.orge[0m
e[2m2026-07-22 21:54:41.114 INFO e[0;1;90mNodeJsDirectoryLock e[0mCleaning stale storage lock for ota - PID 117 reused (token mismatch)e[0m
e[2m2026-07-22 21:54:41.120 INFO e[0;1;90mEndpoint e[39mserver-2-134b.ota-provider e[0mready e[34mendpoint#: e[2;39m1 e[0;34mtype: e[2;39mOtaProvider (0x14, rev 1) e[0;34mbehaviors: e[32m✓otaSoftwareUpdateProvider ✓descriptor ✓softwareupdatese[0m
e[2m2026-07-22 21:54:41.121 INFO e[0;1;90mCertificateAuthority e[0mLoaded stored credentials with ID 0e[0m
e[2m2026-07-22 21:54:41.146 NOTICE e[0;1;90mFabricAuthority e[0;32mRotated NOC for fabric 1e[0m
e[2m2026-07-22 21:54:41.151 WARN e[0;1;90mCommission~ontroller e[0;33mBLE is not enabled on this platforme[0m
e[2m2026-07-22 21:54:41.152 NOTICE e[0;1;90mNode e[32mserver-2-134b e[0;32mgoing onlinee[0m
e[2m2026-07-22 21:54:41.155 INFO e[0;1;90mServerNetworkRuntime e[0mTCP transport enabled (incoming=true, outgoing=true)e[0m
e[2m2026-07-22 21:54:41.163 INFO e[0;1;90mNetworkProfiles e[0mConfigure profile fast e[34mexchanges: e[2;39m200 e[0;34madditionalMrpDelay: e[2;39m0e[0m
e[2m2026-07-22 21:54:41.164 NOTICE e[0;1;90mNode e[32mserver-2-134b e[0;32mis onlinee[0m
e[2m2026-07-22 21:54:41.165 INFO e[0;1;90mFabricAccessControl e[0mACL List updated e[34mprivilege: e[2;39m5 e[0;34mauthMode: e[2;39m2 e[0;34msubjects: e[2;39m112233 e[0;34mtargets: e[2;39mnull e[0;34mfabricIndex: e[2;39m1 e[0;34mprivilege: e[2;39m3 e[0;34mauthMode: e[2;39m2 e[0;34msubjects: targets: e[2;39m{ cluster: 41, endpoint: 1, deviceType: null } e[0;34mfabricIndex: e[2;39m1 e[0;34mprivilege: e[2;39m3 e[0;34mauthMode: e[2;39m2 e[0;34msubjects: targets: e[2;39m{ cluster: 1364, endpoint: 2, deviceType: null } e[0;34mfabricIndex: e[2;39m1e[0m
e[2m2026-07-22 21:54:41.181 INFO e[0;1;90mMdnsAdvertisement e[0mPublishing e[34mkind: e[2;39moperational e[0;34mservice: e[2;39mmdns:66B13EAC39DEBCC5-000000000001B669._matter._tcp.locale[0m
e[2m2026-07-22 21:54:41.182 INFO e[0;1;90mSoftwareUp~teManager e[0mScheduling first OTA update check in 7m 23se[0m
e[2m2026-07-22 21:54:41.189 NOTICE e[0;1;90mController~ndHandler e[0;32mMatter Controller startede[0m
e[2m2026-07-22 21:54:41.190 INFO e[0;1;90mController~ndHandler e[0mOTA event handlers registerede[0m
e[2m2026-07-22 21:54:41.197 INFO e[0;1;90mWebRtcTran~torServer e[0mWebRtcTransportRequestor initialized on endpoint=2 (id="camera-controller")e[0m
e[2m2026-07-22 21:54:41.205 INFO e[0;1;90mEndpoint e[39mserver-2-134b.camera-controller e[0mready e[34mendpoint#: e[2;39m2 e[0;34mtype: e[2;39mCameraController (0x0147, rev 1) e[0;34mbehaviors: e[32m✓webRtcTransportRequestor ✓descriptore[0m
e[2m2026-07-22 21:54:41.206 INFO e[0;1;90mController~ndHandler e[0mWebRTC callback bridge wirede[0m
e[2m2026-07-22 21:54:41.207 INFO e[0;1;90mController~ndHandler e[0mFound 0 nodes:e[0m
e[2m2026-07-22 21:54:41.207 INFO e[0;1;90mController~ndHandler e[0mAll 0 nodes initialized, starting connectionse[0m
e[2m2026-07-22 21:54:41.210 NOTICE e[0;1;90mWebServer e[0;32mWebserver listening on http://172.30.32.1:5580e[0m
e[2m2026-07-22 21:54:41.211 NOTICE e[0;1;90mWebSocketC~erHandler e[0;32mStarting server: matter-server/1.2.6 (matter.js/0.17.6-alpha.0-20260715-3585d95fe)e[0m
e[2m2026-07-22 21:54:41.213 NOTICE e[0;1;90mWebServer e[0;32mWebserver listening on http://127.0.0.1:5580e[0m
e[2m2026-07-22 21:54:45.939 INFO e[0;1;90mDclCertifi~teService e[0mCertificate update failed e[31m[e[1mdcl-responsee[0;31m] Error fetching /dcl/pki/root-certificates from DCL: 500 - The operation was aborted due to timeout: The operation was aborted due to timeoute[0m
e[2m2026-07-22 21:54:45.961 INFO e[0;1;90mDclVendorInfoService e[0mError updating vendor information e[31m[e[1mdcl-responsee[0;31m] Error fetching /dcl/vendorinfo/vendors from DCL: 500 - The operation was aborted due to timeout: The operation was aborted due to timeoute[0m
e[2m2026-07-22 21:55:13.925 INFO e[0;1;90mWebSocketC~erHandler e[0m[0] WebSocket connection establishede[0m
e[2m2026-07-22 21:55:13.934 INFO e[0;1;90mWebSocketC~erHandler e[0mWebSocket server start_listeninge[0m
e[2m2026-07-22 21:55:13.934 INFO e[0;1;90mWebSocketC~erHandler e[0mWebSocket server start_listening. Returned 0 nodese[0m
e[2m2026-07-22 21:55:13.936 INFO e[0;1;90mConfigStorage e[0mSet config key fabricLabel to Homee[0m
e[2m2026-07-22 22:02:04.186 INFO e[0;1;90mSoftwareUp~teManager e[0mNo updatable nodes founde[0m
e[2m2026-07-22 23:13:26.281 INFO e[0;1;90mBorderRouterRegistry e[0mBR instance dropped (no valid xa) qname="otTRELde91a3a9b8eeba03._trel._udp.local" source=trel xa=missing nn="" vn=""e[0m
e[2m2026-07-23 00:14:28.008 INFO e[0;1;90mBorderRouterRegistry e[0mBR instance dropped (no valid xa) qname="otTRELde91a3a9b8eeba03._trel._udp.local" source=trel xa=missing nn="" vn=""e[0m
e[2m2026-07-23 00:55:57.486 INFO e[0;1;90mBorderRouterRegistry e[0mBR instance dropped (no valid xa) qname="otTRELde91a3a9b8eeba03._trel._udp.local" source=trel xa=missing nn="" vn=""e[0m
e[2m2026-07-23 01:56:33.914 INFO e[0;1;90mBorderRouterRegistry e[0mBR instance dropped (no valid xa) qname="Home Assistant OpenThread Border Router de91a3a9b8eeba03._meshcop._udp.local" source=meshcop xa=missing nn="" vn=""e[0m
e[2m2026-07-23 08:30:19.236 INFO e[0;1;90mBorderRouterRegistry e[0mBR instance dropped (no valid xa) qname="Home Assistant OpenThread Border Router de91a3a9b8eeba03._meshcop._udp.local" source=meshcop xa=missing nn="" vn=""e[0m
e[2m2026-07-23 09:13:06.786 INFO e[0;1;90mWebSocketC~erHandler e[0m[0] WebSocket connection closede[0m
e[2m2026-07-23 09:13:06.786 INFO e[0;1;90mWebSocketC~erHandler e[0m[0] Releasing fabric label ownership (owning connection closed)e[0m
e[2m2026-07-23 09:13:22.071 INFO e[0;1;90mWebSocketC~erHandler e[0m[1] WebSocket connection establishede[0m
e[2m2026-07-23 09:13:22.078 INFO e[0;1;90mWebSocketC~erHandler e[0mWebSocket server start_listeninge[0m
e[2m2026-07-23 09:13:22.078 INFO e[0;1;90mWebSocketC~erHandler e[0mWebSocket server start_listening. Returned 0 nodese[0m
e[2m2026-07-23 09:13:22.081 INFO e[0;1;90mConfigStorage e[0mSet config key fabricLabel to Homee[0m
e[2m2026-07-23 09:15:48.284 INFO e[0;1;90mBorderRouterRegistry e[0mBR instance dropped (no valid xa) qname="otTRELde91a3a9b8eeba03._trel._udp.local" source=trel xa=missing nn="" vn=""e[0m
EDIT:
Matter over WiFi works. I was able to connect a Lightbulb. But i used my Smarpthone with HA Companion App to connect it. Maybe there is a problem sharing information between my LAN and WiFi network?
