Matter Plug doesnt connect to Home Assistant
i bought these ones: Amazon.de
Tried to install that with my phone directly to Home Assistant but it doesnt work.
It says (in German)
“Gerät konnte nicht hinzugefügt werden. Möglicherweise musst du dein gerät neu starten, beor du es zu deinem zuhause hinzufügen kannst.”
The Plug is not blinking anymore, its just constant blue.
But it is not in Home Assistant…
My Home Assistant is IPv6 active with Automatic
Why? Any ideas?
I already hat Meross Matter Plugs installed in the same way.
I’m not sure, but check to make sure the phone’s bluetooth is on, and at least for iOS, make sure the phone is on the 2.4GHz WiFi network that you want the device to be used with, otherwise the iPhone will give it the wrong WiFi information.
I tried to use 2,4GHz only but doenst work :confused:
Any other ideas? I created own 2,4GHz but that doesnt help. IPv6 is enabled in Home Assistant and also in Unifi network.
And sure bluetooth is on. I also see “Configuration” after “Connecting”… but than that error
