Matter Server crashing with unsupported access
I’m playing around with a new matter setup, and trying to manually configure node-to-node bindings. Along the way hitting some random errors and in the matter server. I see this error (Unsupported cluster access). What does it even mean?
2025-03-29 13:36:25.911 (MainThread) INFO [matter_server.server.device_controller] Removing Node ID 1.
2025-03-29 13:36:25.911 (MainThread) INFO [matter_server.server.device_controller] Node ID 1 successfully removed from Matter server.
2025-03-29 13:36:25.912 (Dummy-2) CHIP_PROGRESS [chip.native.DIS] Found an existing secure session to [1:0000000000000001]!
2025-03-29 13:36:25.912 (Dummy-2) CHIP_PROGRESS [chip.native.DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
2025-03-29 13:36:25.912 (Dummy-2) CHIP_PROGRESS [chip.native.EM] <<< [E:3464i S:51690 M:93806368] (S) Msg TX from 000000000001B669 to 1:0000000000000001 [5891] [UDP:[fd5b:4e8b:8f65:1:57a2:be42:5851:c54]:5540] --- Type 0001:02 (IM:ReadRequest) (B:51)
2025-03-29 13:36:25.913 (Dummy-2) CHIP_PROGRESS [chip.native.EM] ??1 [E:3464i with Node: <0000000000000001, 1> S:51690 M:93806368] (S) Msg Retransmission to 1:0000000000000001 in 940ms [State:Idle II:800 AI:2000 AT:4000]
2025-03-29 13:36:25.944 (Dummy-2) CHIP_PROGRESS [chip.native.EM] >>> [E:3464i S:51690 M:222009293 (Ack:93806368)] (S) Msg RX from 1:0000000000000001 [5891] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:67)
2025-03-29 13:36:25.945 (Dummy-2) CHIP_PROGRESS [chip.native.CTL] OnReadAttributeFailure IM Error 0x0000057E: General error: 0x7e (UNSUPPORTED_ACCESS)
2025-03-29 13:36:25.945 (Dummy-2) CHIP_ERROR [chip.native.CTL] Remove Current Fabric Failed : IM Error 0x0000057E: General error: 0x7e (UNSUPPORTED_ACCESS)
2025-03-29 13:36:25.945 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to unpair device: IM Error 0x0000057E: General error: 0x7e (UNSUPPORTED_ACCESS)
2025-03-29 13:36:25.945 (MainThread) WARNING [matter_server.server.device_controller] Removing current fabric from device failed: IM Error 0x0000057E: General error: 0x7e (UNSUPPORTED_ACCESS)
