After few resets and changing the channel back to 15 I got the switch blinking again. Looks like there are mDNS issues:
(Dummy-2) CHIP_DETAIL [chip.native.DIS] mDNS broadcast had only partial success: 14 successes and 1 failures.
(Dummy-2) CHIP_DETAIL [chip.native.DIS] SRV record already actively processed.
(Dummy-2) CHIP_DETAIL [chip.native.DIS] Warning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachable
Full matter server logs here:
s6-rc: info: service banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
e[34m-----------------------------------------------------------e[0m
e[34m Add-on: Matter Servere[0m
e[34m Matter WebSocket Server for Home Assistant Matter support.e[0m
e[34m Add-on version: 7.0.0e[0m
e[32m You are running the latest version of this add-on.e[0m
e[34m System: Home Assistant OS 14.2 (amd64 / generic-x86-64)e[0m
e[34m Home Assistant Core: 2025.2.4e[0m
e[34m Home Assistant Supervisor: 2025.02.1e[0m
e[34m Please, share the above information when looking for helpe[0m
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
s6-rc: info: service banner successfully started
s6-rc: info: service matter-server: starting
s6-rc: info: service matter-server successfully started
s6-rc: info: service legacy-services: starting
[00:31:09] INFO: e[32mStarting Matter Server...e[0m
s6-rc: info: service legacy-services successfully started
[00:31:09] INFO: e[32mUsing 'wlp0s20f3' as primary network interface.e[0m
[00:31:09] INFO: e[32mSuccessfully send discovery information to Home Assistant.e[0m
e[32m2025-02-19 00:31:11.264e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.stack]e[0m Initializing CHIP/Matter Logging...
e[32m2025-02-19 00:31:11.265e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.stack]e[0m Initializing CHIP/Matter Controller Stack...
[1739953871.284493][117:117] CHIP:CTL: Setting attestation nonce to random value
[1739953871.284683][117:117] CHIP:CTL: Setting CSR nonce to random value
[1739953871.285268][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1739953871.287400][117:117] CHIP:DL: Wrote settings to /tmp/chip_kvs
[1739953871.287587][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_factory.ini
[1739953871.287687][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_config.ini
[1739953871.287722][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_counters.ini
[1739953871.288603][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1739953871.288617][117:117] CHIP:DL: NVS set: chip-counters/reboot-count = 3 (0x3)
[1739953871.288876][117:117] CHIP:DL: Got Ethernet interface: enp1s0
[1739953871.289025][117:117] CHIP:DL: Found the primary Ethernet interface:enp1s0
[1739953871.289167][117:117] CHIP:DL: Got WiFi interface: wlp0s20f3
[1739953871.289521][117:117] CHIP:DL: Found the primary WiFi interface:wlp0s20f3
e[32m2025-02-19 00:31:11.289e[0m (MainThread) e[1;30mINFOe[0m e[34m[chip.storage]e[0m Initializing persistent storage from file: /data/chip.json
e[32m2025-02-19 00:31:11.289e[0m (MainThread) e[1;30mINFOe[0m e[34m[chip.storage]e[0m Loading configuration from /data/chip.json...
e[32m2025-02-19 00:31:11.290e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/icdfl, Value = 0x55e30756ee00 (512)e[0m
e[32m2025-02-19 00:31:11.290e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 4
e[0m
e[32m2025-02-19 00:31:11.290e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.IN]e[0m e[2;32mUDP::Init bind&listen port=0e[0m
e[32m2025-02-19 00:31:11.290e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.IN]e[0m e[2;32mUDP::Init bound to port=50847e[0m
e[32m2025-02-19 00:31:11.290e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.IN]e[0m e[2;32mUDP::Init bound to port=56140e[0m
e[32m2025-02-19 00:31:11.290e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.IN]e[0m e[2;32mBLEBase::Init - setting/overriding transporte[0m
e[32m2025-02-19 00:31:11.290e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.IN]e[0m e[2;32mTransportMgr initializede[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.FP]e[0m e[2;32mInitializing FabricTable from persistent storagee[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/lkgt, Value = 0x7ffd4f3c2d40 (18)e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 8
e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.TS]e[0m Last Known Good Time: 2023-10-14T01:16:48
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/fidx, Value = 0x7ffd4f3c2fc0 (44)e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 10
e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/n, Value = 0x7ffd4f3c2a20 (400)e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 244
e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/r, Value = 0x7ffd4f3c2880 (400)e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 231
e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/m, Value = 0x7ffd4f3c2590 (44)e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 9
e[0m
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.FP]e[0m Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x3A131F4ED5AB5891, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0x134B
e[32m2025-02-19 00:31:11.291e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/fs/c, Value = 0x7ffd4f3c2e70 (36)e[0m
e[32m2025-02-19 00:31:11.292e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Not Found
e[0m
e[32m2025-02-19 00:31:11.292e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/gcc, Value = 0x7ffd4f3c2f18 (4)e[0m
e[32m2025-02-19 00:31:11.292e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 4
e[0m
e[32m2025-02-19 00:31:11.292e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/gdc, Value = 0x7ffd4f3c2f18 (4)e[0m
e[0m
e[32m2025-02-19 00:31:11.292e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = g/gcc, Value = 0x7ffd4f3c2f18 (4)e[0m
e[32m2025-02-19 00:31:11.292e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = g/gdc, Value = 0x7ffd4f3c2f18 (4)e[0m
e[32m2025-02-19 00:31:11.293e[0m (MainThread) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.ZCL]e[0m Using ZAP configuration...
e[32m2025-02-19 00:31:11.294e[0m (MainThread) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.IN]e[0m CASE Server enabling CASE session setups
e[32m2025-02-19 00:31:11.294e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.IN]e[0m e[2;32mSecureSession[0x55e3074f2d00]: Allocated Type:2 LSID:38613e[0m
e[32m2025-02-19 00:31:11.294e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.SC]e[0m e[2;32mAllocated SecureSession (0x55e3074f2d00) - waiting for Sigma1 msge[0m
e[32m2025-02-19 00:31:11.294e[0m (MainThread) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mSystem State Initialized...e[0m
e[32m2025-02-19 00:31:11.294e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mCHIP task runninge[0m
e[32m2025-02-19 00:31:11.295e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mHandlePlatformSpecificBLEEvent 32786e[0m
e[32m2025-02-19 00:31:11.369e[0m (MainThread) e[1;30mINFOe[0m e[34m[chip.CertificateAuthority]e[0m Loading certificate authorities from storage...
e[32m2025-02-19 00:31:11.369e[0m (MainThread) e[1;30mINFOe[0m e[34m[chip.CertificateAuthority]e[0m New CertificateAuthority at index 1
e[32m2025-02-19 00:31:11.369e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = ExampleOpCredsCAKey1, Value = 0x7f12837fcf90 (97)e[0m
e[32m2025-02-19 00:31:11.370e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 97
e[0m
e[32m2025-02-19 00:31:11.370e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = ExampleOpCredsICAKey1, Value = 0x7f12837fcf90 (97)e[0m
e[0m
e[32m2025-02-19 00:31:11.370e[0m (MainThread) e[1;30mINFOe[0m e[34m[chip.CertificateAuthority]e[0m Loading fabric admins from storage...
e[32m2025-02-19 00:31:11.370e[0m (MainThread) e[1;30mINFOe[0m e[34m[chip.FabricAdmin]e[0m New FabricAdmin: FabricId: 0x0000000000000002, VendorId = 0x134B
e[32m2025-02-19 00:31:11.370e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.stack]e[0m CHIP Controller Stack initialized.
e[32m2025-02-19 00:31:11.371e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.server]e[0m Starting the Matter Server...
e[32m2025-02-19 00:31:11.373e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.helpers.paa_certificates]e[0m Fetching the latest PAA root certificates from DCL.
e[32m2025-02-19 00:31:12.896e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.helpers.paa_certificates]e[0m Fetched 65 PAA root certificates from DCL.
e[32m2025-02-19 00:31:12.896e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.helpers.paa_certificates]e[0m Fetching the latest PAA root certificates from Git.
e[32m2025-02-19 00:31:13.794e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.helpers.paa_certificates]e[0m Fetched 2 PAA root certificates from Git.
e[32m2025-02-19 00:31:13.796e[0m (MainThread) e[1;30mINFOe[0m e[34m[chip.FabricAdmin]e[0m Allocating new controller with CaIndex: 1, FabricId: 0x0000000000000002, NodeId: 0x000000000001B669, CatTags: []
e[32m2025-02-19 00:31:13.798e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mCreating New Device Controllere[0m
e[32m2025-02-19 00:31:13.798e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.CTL]e[0m Setting attestation nonce to random value
e[32m2025-02-19 00:31:13.799e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.CTL]e[0m Setting CSR nonce to random value
e[32m2025-02-19 00:31:13.799e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.SPT]e[0m Using device attestation PAA trust store path /data/credentials.
e[32m2025-02-19 00:31:13.827e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = ExampleCARootCert1, Value = 0x7f1274011fd0 (600)e[0m
e[32m2025-02-19 00:31:13.827e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 410
e[0m
e[32m2025-02-19 00:31:13.827e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = ExampleCAIntermediateCert1, Value = 0x7f1274011d70 (600)e[0m
e[0m
e[32m2025-02-19 00:31:13.827e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.CTL]e[0m Generating NOC
e[32m2025-02-19 00:31:13.828e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/r, Value = 0x7f12837fbce0 (400)e[0m
e[32m2025-02-19 00:31:13.828e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 231
e[0m
e[32m2025-02-19 00:31:13.829e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/n, Value = 0x7f12837fbce0 (400)e[0m
e[32m2025-02-19 00:31:13.829e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 244
e[0m
e[32m2025-02-19 00:31:13.829e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/r, Value = 0x7f1274012a20 (400)e[0m
e[32m2025-02-19 00:31:13.829e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 231
e[0m
e[32m2025-02-19 00:31:13.829e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.FP]e[0m Validating NOC chain
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.FP]e[0m NOC chain validation successful
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.FP]e[0m Updated fabric at index: 0x1, Node ID: 0x000000000001B669
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.TS]e[0m Last Known Good Time: 2023-10-14T01:16:48
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.TS]e[0m New proposed Last Known Good Time: 2021-01-01T00:00:00
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.TS]e[0m Retaining current Last Known Good Time
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/sri, Value = 0x7f12837fb410 (966)e[0m
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Not Found
e[0m
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = g/fs/c, Value = 0x7f12837fbce0 (7)e[0m
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = f/1/m, Value = 0x7f12837fbbb0 (9)e[0m
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.FP]e[0m Metadata for Fabric 0x1 persisted to storage.
e[32m2025-02-19 00:31:13.834e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = f/1/n, Value = 0x7f127400e780 (244)e[0m
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = f/1/i, Value = 0x7f127400ec10 (231)e[0m
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.TS]e[0m Committing Last Known Good Time to storage: 2023-10-14T01:16:48
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = g/lkgt, Value = 0x7f12837fbc70 (8)e[0m
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = g/fs/c, Value = 0x7f12837fbcbf (0)e[0m
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mBuf not big enough
e[0m
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::DeleteKeyValue: Key = g/fs/ce[0m
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.CTL]e[0m Joined the fabric at index 1. Fabric ID is 0x0000000000000002 (Compressed Fabric ID: 3A131F4ED5AB5891)
e[32m2025-02-19 00:31:13.835e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.DIS]e[0m Updating services using commissioning mode 0
e[32m2025-02-19 00:31:13.837e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.DIS]e[0m CHIP minimal mDNS started advertising.
e[32m2025-02-19 00:31:13.837e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mUsing WiFi MAC for hostnamee[0m
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.DIS]e[0m Advertise operational node 3A131F4ED5AB5891-000000000001B669
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mResponding with _matter._tcp.locale[0m
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mResponding with 3A131F4ED5AB5891-000000000001B669._matter._tcp.locale[0m
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mResponding with 00CE39D50C8F0000.locale[0m
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mResponding with _I3A131F4ED5AB5891._sub._matter._tcp.locale[0m
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.DIS]e[0m CHIP minimal mDNS configured as 'Operational device'; instance name: 3A131F4ED5AB5891-000000000001B669.
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.DIS]e[0m mDNS broadcast full failed in 1 separate send attempts.
e[32m2025-02-19 00:31:13.838e[0m (Dummy-2) e[1;30mCHIP_ERRORe[0m e[34m[chip.native.DIS]e[0m e[31mFailed to advertise records: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.DIS]e[0m mDNS service published: _matter._tcp
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_PROGRESSe[0m e[34m[chip.native.SPT]e[0m Setting up group data for Fabric Index 1 with Compressed Fabric ID:
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.SPT]e[0m e[2;32m0x3a, 0x13, 0x1f, 0x4e, 0xd5, 0xab, 0x58, 0x91, e[0m
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/g, Value = 0x7f12837fc710 (128)e[0m
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 23
e[0m
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::GetKeyValue: Key = f/1/k/0, Value = 0x7f12837fc5e0 (128)e[0m
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mKey Found 97
e[0m
e[32m2025-02-19 00:31:13.841e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.CTL]e[0m e[2;32mStorageAdapter::SetKeyValue: Key = f/1/k/0, Value = 0x7f12837fc5e0 (97)e[0m
e[32m2025-02-19 00:31:13.848e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.vendor_info]e[0m Loading vendor info from storage.
e[32m2025-02-19 00:31:13.852e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.vendor_info]e[0m Loaded 287 vendors from storage.
e[32m2025-02-19 00:31:13.852e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.vendor_info]e[0m Fetching the latest vendor info from DCL.
e[32m2025-02-19 00:31:13.970e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.vendor_info]e[0m Fetched 286 vendors from DCL.
e[32m2025-02-19 00:31:13.970e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.vendor_info]e[0m Saving vendor info to storage.
e[32m2025-02-19 00:31:13.977e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.device_controller]e[0m Loaded 0 nodes from stored configuration
e[32m2025-02-19 00:31:13.987e[0m (MainThread) e[1;30mINFOe[0m e[34m[matter_server.server.server]e[0m Matter Server successfully initialized.
e[32m2025-02-19 01:22:49.533e[0m (Dummy-3) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mGot IP address on interface: wlp0s20f3 IP: 192.168.0.111e[0m
e[32m2025-02-19 01:22:49.534e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mHandlePlatformSpecificBLEEvent 32770e[0m
e[32m2025-02-19 02:22:49.535e[0m (Dummy-3) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mGot IP address on interface: wlp0s20f3 IP: 192.168.0.111e[0m
e[32m2025-02-19 02:22:49.535e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mHandlePlatformSpecificBLEEvent 32770e[0m
e[32m2025-02-19 03:22:49.534e[0m (Dummy-3) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mGot IP address on interface: wlp0s20f3 IP: 192.168.0.111e[0m
e[32m2025-02-19 03:22:49.535e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mHandlePlatformSpecificBLEEvent 32770e[0m
e[32m2025-02-19 04:22:49.523e[0m (Dummy-3) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mGot IP address on interface: wlp0s20f3 IP: 192.168.0.111e[0m
e[32m2025-02-19 04:22:49.524e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DL]e[0m e[2;32mHandlePlatformSpecificBLEEvent 32770e[0m
e[32m2025-02-19 09:17:47.067e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.064e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.065e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.065e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.065e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.066e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.068e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.069e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.070e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.072e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.073e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.073e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.074e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.075e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.076e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.077e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.078e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.079e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.080e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.081e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.082e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.083e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.084e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.085e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.086e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.088e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mWarning: Attempt to mDNS broadcast failed on enp1s0: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachablee[0m
e[32m2025-02-19 09:17:48.089e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mmDNS broadcast had only partial success: 14 successes and 1 failures.e[0m
e[32m2025-02-19 09:17:48.089e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
e[32m2025-02-19 09:17:48.090e[0m (Dummy-2) e[1;30mCHIP_DETAILe[0m e[34m[chip.native.DIS]e[0m e[2;32mSRV record already actively processed.e[0m
