Matter unstable unless local TBR running
I am using home assistant on a raspberry pi 5 and have a small thread network.
I have a Apple TV 4k and 2 homepod minis running the network.
All matter devices seem to drop of the network unless I run the OTBR add on but that in itself doesnt seem right looking at the logs (some attached) If i stop the OTBR add on the whole matter network becomes unstable.
Just looking at why the logs seem to point to it not working however in reality everything works perfect.
[12:47:28] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Jan 14 2025 21:08:25) starting
 Add-on: OpenThread Border Router
 OpenThread Border Router add-on
 Add-on version: 2.13.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 15.2  (aarch64 / raspberrypi5-64)
 Home Assistant Core: 2025.6.1
 Home Assistant Supervisor: 2025.05.5
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[12:47:28] INFO: Flashing firmware is disabled
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service otbr-agent: starting
[12:47:29] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b067e5ac-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/ttyUSB0?uart-baudrate=460800&uart-init-deassert
[NOTE]-AGENT---: Radio URL: trel://end0
[NOTE]-ILS-----: Infra link selected: end0
60d.20:56:07.241 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.053 [N] RoutingManager: BR ULA prefix: fd10:f003:344d::/48 (loaded)
00:00:00.053 [N] RoutingManager: Local on-link prefix: fdd9:a5:498:4cf8::/64
00:00:00.071 [N] Mle-----------: Role disabled -> detached
00:00:00.084 [N] P-Netif-------: Changing interface state to up.
00:00:00.093 [W] P-Netif-------: Failed to process request#2: No such process
00:00:00.094 [W] P-Netif-------: Failed to process request#6: No such process
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
s6-rc: info: service otbr-web: starting
s6-rc: info: service otbr-web successfully started
[12:47:29] INFO: Starting otbr-web...
[INFO]-WEB-----: Running 0.3.0-b067e5ac-dirty
listenAddr not specified, using default ::
[INFO]-WEB-----: Border router web started on wpan0
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
00:00:00.463 [W] P-Daemon------: Daemon read: Connection reset by peer
[12:47:30] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
00:00:11.570 [N] Mle-----------: RLOC16 a800 -> fffe
00:00:12.061 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:13.093 [N] Mle-----------: RLOC16 fffe -> 3412
00:00:13.095 [N] Mle-----------: Role detached -> child
00:00:13.101 [W] P-Netif-------: Successfully added an external route fc00::/7 in kernel
00:00:13.102 [W] P-Netif-------: Successfully added an external route fdd5:615:c3b8:ffff:0:0::/96 in kernel
00:00:13.914 [W] DuaManager----: Failed to perform next registration: NotFound
00:00:28.973 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:92, chksum:7cce, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:all
00:00:28.973 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:00:28.973 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:00:33.261 [N] MeshForwarder-: Dropping rx frag frame, error:Drop, len:75, src:4676992b44418f73, dst:0xffff, sec:yes, tag:18209, offset:128, dglen:203
00:00:33.677 [N] MeshForwarder-: Dropping rx frag frame, error:Drop, len:91, src:3202e0aac9cfd319, dst:0xffff, sec:yes, tag:63018, offset:128, dglen:219
00:00:35.911 [N] MeshForwarder-: Dropping (reassembly queue) IPv6 UDP msg, len:219, chksum:2415, ecn:no, sec:yes, error:ReassemblyTimeout, prio:net, rss:-80.0, radio:15.4
00:00:35.911 [N] MeshForwarder-:     src:[fe80:0:0:0:6c4c:cc68:e36f:774a]:19788
00:00:35.911 [N] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
00:00:35.911 [N] MeshForwarder-: Dropping (reassembly queue) IPv6 UDP msg, len:203, chksum:6375, ecn:no, sec:yes, error:ReassemblyTimeout, prio:net, rss:-53.0, radio:15.4
00:00:35.911 [N] MeshForwarder-:     src:[fe80:0:0:0:3002:e0aa:c9cf:d319]:19788
00:00:35.911 [W] DuaManager----: Failed to perform next registration: NotFound
00:00:52.960 [N] Mle-----------: RLOC16 3412 -> d800
00:00:52.963 [N] Mle-----------: Role child -> router
00:00:52.963 [N] Mle-----------: Partition ID 0x32e3e5cd
00:00:53.366 [N] MeshForwarder-: Dropping IPv6 UDP msg, len:203, chksum:879f, ecn:no, sec:yes, error:Drop, prio:net, radio:all
00:00:53.366 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:00:53.366 [N] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
00:00:53.428 [W] P-Netif-------: Successfully deleted an external route fc00::/7 in kernel
00:00:55.234 [W] Mle-----------: Failed to process Link Accept: Security
00:00:55.732 [W] P-Netif-------: Successfully added an external route fc00::/7 in kernel
00:00:55.914 [N] MeshForwarder-: Dropping (reassembly queue) IPv6 UDP msg, len:149, chksum:119b, ecn:no, sec:yes, error:ReassemblyTimeout, prio:net, rss:-59.0, radio:15.4
00:00:55.914 [N] MeshForwarder-:     src:[fe80:0:0:0:4476:992b:4441:8f73]:19788
00:00:55.914 [N] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
00:00:55.914 [W] DuaManager----: Failed to perform next registration: NotFound
00:00:56.339 [N] MeshForwarder-: Dropping rx frag frame, error:Drop, len:64, src:9e0b087f6c5745d2, dst:0xffff, sec:yes, tag:57066, offset:128, dglen:192
00:00:57.908 [N] MeshForwarder-: Dropping (reassembly queue) IPv6 UDP msg, len:192, chksum:3fe9, ecn:no, sec:yes, error:ReassemblyTimeout, prio:net, rss:-85.0, radio:15.4
00:00:57.908 [N] MeshForwarder-:     src:[fe80:0:0:0:cc5e:f296:c169:580c]:19788
00:00:57.908 [N] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
00:00:58.906 [N] MeshForwarder-: Dropping (reassembly queue) IPv6 UDP msg, len:192, chksum:1bca, ecn:no, sec:yes, error:ReassemblyTimeout, prio:net, rss:-59.0, radio:15.4
00:00:58.906 [N] MeshForwarder-:     src:[fe80:0:0:0:cf2:28ec:3b2e:c8e]:19788
00:00:58.906 [N] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
00:00:58.906 [N] MeshForwarder-: Dropping (reassembly queue) IPv6 UDP msg, len:192, chksum:44ca, ecn:no, sec:yes, error:ReassemblyTimeout, prio:net, rss:-53.0, radio:15.4
00:00:58.906 [N] MeshForwarder-:     src:[fe80:0:0:0:3002:e0aa:c9cf:d319]:19788
00:01:10.430 [N] MeshForwarder-: Dropping rx frag frame, error:Drop, len:91, src:0ef228ec3b2e0c8e, dst:0xffff, sec:yes, tag:57103, offset:128, dglen:219
00:01:12.892 [N] MeshForwarder-: Dropping (reassembly queue) IPv6 UDP msg, len:219, chksum:175f, ecn:no, sec:yes, error:ReassemblyTimeout, prio:net, rss:-53.0, radio:15.4
00:01:12.892 [N] MeshForwarder-:     src:[fe80:0:0:0:3002:e0aa:c9cf:d319]:19788
00:01:12.892 [N] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
00:01:49.501 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:90, chksum:62e8, ecn:no, to:0x3400, sec:yes, error:NoAck, prio:low, radio:15.4
00:01:49.501 [N] MeshForwarder-:     src:[fd10:f003:344d:1:1c7e:9c4b:73dc:a12d]:57867
00:01:49.501 [N] MeshForwarder-:     dst:[fd10:f003:344d:1:3687:d331:f13e:67a8]:5540
00:01:49.671 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:90, chksum:46dd, ecn:no, to:0x3400, sec:yes, error:NoAck, prio:low, radio:15.4
00:01:49.671 [N] MeshForwarder-:     src:[fd10:f003:344d:1:1c7e:9c4b:73dc:a12d]:57867
00:01:49.671 [N] MeshForwarder-:     dst:[fd10:f003:344d:1:3687:d331:f13e:67a8]:5540
00:01:51.023 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:01:51.023 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:90, chksum:04e8, ecn:no, to:0x3400, sec:yes, error:ChannelAccessFailure, prio:low, radio:15.4
00:01:51.023 [N] MeshForwarder-:     src:[fd10:f003:344d:1:1c7e:9c4b:73dc:a12d]:57867
00:01:51.023 [N] MeshForwarder-:     dst:[fd10:f003:344d:1:3687:d331:f13e:67a8]:5540
00:05:08.545 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:e893, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:05:08.545 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:05:08.545 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:06:50.535 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:ea7c, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:06:50.535 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:06:50.535 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:06:51.576 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:efa3, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:06:51.576 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:06:51.576 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:06:52.567 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:e038, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:06:52.567 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:06:52.567 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:10:14.574 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:e54b, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:10:14.574 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:10:14.574 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:10:15.604 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:a101, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:10:15.604 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:10:15.604 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:10:16.578 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:e033, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:10:16.578 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:10:16.578 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:15:33.255 [N] MeshForwarder-: Dropping rx frame, aError:Drop, len:20, seqnum:169, type:Cmd(6), src:000f93ffffa6acae, dst:0xffff, sec:no, ackreq:no, radio:15.4
00:16:53.652 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:f24c, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:16:53.652 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:16:53.652 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:16:54.619 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:e749, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:16:54.619 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:16:54.619 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:18:35.629 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:3831, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:18:35.629 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:18:35.629 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:18:36.621 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:60a0, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:18:36.621 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:18:36.621 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:18:37.630 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:9485, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:18:37.630 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:18:37.630 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:42:53.603 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:a35f, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:42:53.603 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:42:53.603 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:42:54.592 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:e81d, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:42:54.592 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:42:54.592 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:42:55.587 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:a600, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:42:55.587 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:42:55.587 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:44:38.540 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:734e, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:44:38.540 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:44:38.540 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:44:39.545 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:fe5a, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:44:39.545 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:44:39.545 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:44:40.575 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:84da, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:44:40.575 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:44:40.575 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:45:14.788 [N] MeshForwarder-: Dropping rx frag frame, error:Duplicated, len:32, src:0xa000, dst:0xffff, sec:yes, tag:22278, offset:0, dglen:71
00:52:38.002 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:8caa, ecn:no, to:daa81cc3592575cb, sec:no, error:NoAck, prio:net, radio:15.4
00:52:38.002 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:52:38.002 [N] MeshForwarder-:     dst:[fe80:0:0:0:d8a8:1cc3:5925:75cb]:19788
00:54:06.471 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:272a, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:54:06.471 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:54:06.471 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:54:07.498 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:1d5f, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:54:07.498 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:54:07.498 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
00:54:08.471 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:479e, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
00:54:08.471 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
00:54:08.471 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:08:59.522 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:4e6b, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:08:59.522 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:08:59.522 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:09:00.679 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:a89b, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:09:00.679 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:09:00.679 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:09:01.597 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:079d, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:09:01.597 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:09:01.597 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:26:40.742 [W] Mle-----------: Failed to process Link Accept: Security
01:26:40.798 [W] Mle-----------: Failed to process Link Accept: Security
01:26:40.818 [W] Mle-----------: Failed to process Link Accept: Security
01:26:40.829 [W] Mle-----------: Failed to process Link Accept: Security
01:26:40.885 [W] Mle-----------: Failed to process Link Accept: Security
01:26:40.954 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:120, chksum:c12a, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:26:40.954 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:26:40.954 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:28:21.251 [W] Mle-----------: Failed to process Link Accept: Security
01:28:21.297 [W] Mle-----------: Failed to process Link Accept: Security
01:30:02.368 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:5746, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:30:02.368 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:30:02.368 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:31:44.341 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:68ba, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:31:44.341 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:31:44.341 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:31:45.352 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:a7fc, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:31:45.352 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:31:45.352 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:31:46.342 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:f10e, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:31:46.342 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:31:46.342 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:35:47.428 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:81d4, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:35:47.428 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:35:47.428 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:35:48.416 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:f040, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:35:48.416 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:35:48.416 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:35:49.414 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:131, chksum:f460, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:35:49.414 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:35:49.414 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:42:01.158 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
01:42:01.158 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:90, chksum:73c7, ecn:no, to:0x7800, sec:yes, error:ChannelAccessFailure, prio:low, radio:15.4
01:42:01.158 [N] MeshForwarder-:     src:[fd10:f003:344d:1:1c7e:9c4b:73dc:a12d]:57867
01:42:01.158 [N] MeshForwarder-:     dst:[fd10:f003:344d:1:90b3:ae97:3f76:d0b6]:5540
01:43:15.318 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:9c31, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:43:15.318 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:43:15.318 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:43:16.857 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:0447, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:43:16.857 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:43:16.857 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:43:18.039 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:acd7, ecn:no, to:ca3d7f229b9671ce, sec:no, error:NoAck, prio:net, radio:15.4
01:43:18.039 [N] MeshForwarder-:     src:[fe80:0:0:0:4cbc:1001:7e5c:7731]:19788
01:43:18.039 [N] MeshForwarder-:     dst:[fe80:0:0:0:c83d:7f22:9b96:71ce]:19788
01:45:14.801 [N] MeshForwarder-: Dropping rx frag frame, error:Duplicated, len:32, src:0xa000, dst:0xffff, sec:yes, tag:22800, offset:0, dglen:71
01:45:32.794 [N] MeshForwarder-: Dropping rx frame, aError:Drop, len:20, seqnum:62, type:Cmd(6), src:000f93ffffa6acae, dst:0xffff, sec:no, ackreq:no, radio:15.4
01:52:09.337 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.346 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.365 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.380 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.536 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.554 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.570 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.611 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.650 [W] Mle-----------: Failed to process Link Accept: Security
01:52:09.662 [W] Mle-----------: Failed to process Link Accept: Security
Drop off the thread network? If the addon isn’t running the network no longer exists.
Do you have them connected to Apple TV?
I’m pretty sure HA will need addon running to talk to the thread devices even with Apple TV. You should be able to use apples “home”(?) app to operate devices using Apple TV.
Sorry I should have clarified. My Apple thread network is preferred with the OTBR joined into it.
The last I heard, earlier in this year, having multiple TBRs makes connectivity unstable, and I understand that the Thread feature “TREL” is one of the main reasons for this. Whether this is the problem here, I don’t really know, just be aware of it.
Yeah I read about that too. What I’m confused about is the logs from the OTBR seems to show it’s not working right but if it’s not running the thread network is unstable. It’s all really weird.
