Does this method still works, can anyone chime in?
I tried different types of sensors in Tuya app while the camera in blinking red(in pairing mode) and tuya never finds it
Hi, I successfully connected today. To pair the camera, you need to set Cam in pair mode, initiate a manual connection by choose a cameratype that generates a Wi-Fi QR code during setup, then hold that QR code in front of the camera to complete the pairing. I used the Tuya app for this process.
Do you have any idea how I can access the recordings on the camera or control its movement? I can’t find any options for this in either the Tuya app or Home Assistant.
I would love to be able to see the camera in Home Assistant for myself, but keep it on the Maxi-Cosi monitor and app for my partner. Judging from the information above, the Maxi-Cosi See (Pro) is a slightly modified Tuya white-label device. If there’s a way to fetch the device key, we can probably use the camera in Home Assistant through LocalTuya while keeping it connected to Maxi-Cosi.
Either way, controlling PTZ movements can often be fixed using LocalTuya when official Tuya doesn’t support it out of the box. I haven’t tried this because I am not allowed to remove the camera from the Maxi-Cosi app.
Just thought it may be worth checking out for some of you without such wife factor restrictions.
