Hi im wondering if anyone can help with the configuration of a Maxico W-UK007S. Ive used the code off ESP Home site and have the plug working in HA. My issue is that I’ve set the default state to Always_On so when I plug it in it always enables the relay. But by doing this the led on the top stays off. if I cycle the relay by button or HA then the light work. it just seems to be on power up. Im new to ESP Home and was wondering if there was an easy fix.
the config as below:
# Maxcio W-UK007S
# Substitutions
substitutions:
# Device Names
device_name: "dishwasher"
friendly_name: "Dishwasher"
# Icon
main_icon: "dishwasher"
# Default Relay State
# Aka: `restore_mode` in documentation
# Options: `RESTORE_DEFAULT_OFF`, `RESTORE_DEFAULT_ON`, `ALWAYS_ON` & `ALWAYS_OFF`
default_state: "ALWAYS_ON"
# Activity State Threshold
# Threshold (number) that the device will change from `Idle` to `Active` if power is greater than or equal to
activity_threshold: "5"
# Basic Config
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
logger:
api:
ota:
time:
- platform: sntp
# Device Specific Config
binary_sensor:
# Push Button (Toggles Relay When Pressed)
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: true
on_press:
- switch.toggle: relay
- platform: status
name: "${friendly_name} Server Status"
switch:
# Relay (As Switch)
- platform: gpio
icon: "mdi:${main_icon}"
pin: GPIO15
restore_mode: "${default_state}"
on_turn_on:
- light.turn_on:
brightness: 100%
transition_length: 0s
on_turn_off:
- light.turn_off:
# WiFi Signal Sensor
- platform: wifi_signal
name: "${friendly_name} WiFi Status"
update_interval: 60s
# Power Monitoring
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: true
cf_pin: GPIO5
cf1_pin: GPIO14
change_mode_every: 3
update_interval: 3s
voltage:
unit_of_measurement: V
accuracy_decimals: 1
filters:
# Map from sensor -> measured value
- calibrate_linear:
- 0.0 -> 0.0
- 602.87506 -> 229.9
- 609.8 -> 232.8
power:
unit_of_measurement: W
accuracy_decimals: 0
filters:
- calibrate_linear:
- 0.0 -> 1.14
- 62.06167 -> 10.93
- 1503.27161 -> 247.6
- 1599.81213 -> 263.7
- 3923.67700 -> 631.4
- 7109.50928 -> 1148.0
- 7237.0857 -> 1193.0
- 7426.71338 -> 1217.0
current:
unit_of_measurement: A
accuracy_decimals: 3
filters:
- calibrate_linear:
- 0.0 -> 0.013
- 0.08208 -> 0.071
- 1.34223 -> 1.066
- 5.57170 -> 4.408
- 6.69184 -> 5.259
- 6.97187 -> 5.540
# Total daily energy sensor
- platform: total_daily_energy
name: "${friendly_name} Daily Energy"
power_id: power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
text_sensor:
# Device Activity State
# e.g. shows as active if power reading above a certain threshold
name: "${friendly_name} Activity State"
lambda: |-
if (id(power).state >= $activity_threshold) {
return {"Active"};
} else {
return {"Idle"};
update_interval: 5s
# Relay State LED
output:
- platform: esp8266_pwm
pin:
number: GPIO0
inverted: true
light:
- platform: monochromatic
output: state_led
