Maximum temperature of Met.no
I changed to another provider (Deutsche Wetter) and I've got pretty good results. It looks accurate. I'll check for a few days with the DW website.
weather.kusel_klaeranlage:
  forecast:
    - datetime: "2026-05-30T00:00:00Z"
      cloud_coverage: 74
      condition: partlycloudy
      precipitation_probability: 14
      pressure: 30.03
      uv_index: 6
      wind_gust_speed: 20.4
      wind_bearing: S
      evaporation: null
      fog_probability: 0
      sun_irradiance: 0
      visibility: 32100
      sun_duration: 6300
      precipitation_duration: 0
      temperature: 81
      templow: 68
      dew_point: 58
      wind_speed: 5.78
      precipitation: 0
      humidity: 72
I ran into the same head scratcher and ended up fixing it by switching to the hourly forecast instead of the daily one. The daily max from Met.no often lands as a midday snapshot instead of the actual high. If you grab the hourly temps and feed them through a simple max template sensor, you get a number that actually tracks the warmest point of the day.
