How can I optimize the automation?
The Xiaomi MCCGQ11LM - Aqara door & window contact sensors are connected via Zigbee2MQTT.
The problem is, whenever I reboot the home assistant, the status of the sensors is unknown and therefore the automation script is not working properly.
arch armv7l
dev false
docker false
hassio false
os_name Linux
python_version 3.7.3
timezone Europe/Vaduz
version 0.97.2
virtualenv true
Lovelace
mode yaml
resources 27
views 6
I always get the message that the door is open, even if the sensor is closed. Only when the first message comes from the sensor, the automation works properly.
It looks like the default value is not used and therefore the wrong status is reported.
value_template: "{{ value_json.contact | default(true) }}"
Current Settings
# MCCGQ11LM - Aqara door & window contact sensor
# "contact" : true,
# "linkquality" : 110,
# "last_seen" : "2019-08-23T17:16:11+02:00",
# "battery" : 100,
# "voltage" : 3015,
# "elapsed" : 807,
# "device" : {
# "ieeeAddr" : "0x00158d0003eef3c6",
# "friendlyName" : "0x00158d0003eef3c6",
# "type" : "EndDevice",
# "nwkAddr" : 57079,
# "manufId" : 4151,
# "manufName" : "LUMI",
# "powerSource" : "Battery",
# "modelId" : "lumi.sensor_magnet.aq2",
# "hwVersion" : 2,
# "swBuildId" : "3000-0001",
# "dateCode" : "20161128",
# "status" : "online"
## binary sensor
- platform: "mqtt"
name: 'Türsensensor 1 Status'
state_topic: "zigbee2mqtt/0x00158d0003eef3c6"
payload_on: true
payload_off: false
availability_topic: "zigbee2mqtt/bridge/state"
payload_available: "online"
payload_not_available: "offline"
device_class: "door"
json_attributes_topic: "zigbee2mqtt/0x00158d0003f13798"
## Automation
- id: door_sensor1_warning_message
alias: Türsensor 1 Warnmeldung
initial_state: true
- seconds: /20
platform: time_pattern
condition:
condition: state
entity_id: binary_sensor.tursensensor_1_status
state: 'off'
for:
seconds: 10
- service: script.appmessage
message: "Tür 1 ist offen. {{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
title: "Warnmeldung Türe 1"
- service: system_log.write
data_template:
message: 'Automations: door_sensor1_status warning'
level: info
system_log
2019-08-25 13:03:14 INFO (MainThread) [homeassistant.components.system_log.external] Automations: boot notifiy
2019-08-25 13:03:20 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:03:40 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:04:20 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:04:40 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:05:00 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:05:20 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:05:40 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:06:00 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status warning
2019-08-25 13:07:00 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status open to closed
019-08-25 13:07:21 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status close to open
2019-08-25 13:07:39 INFO (MainThread) [homeassistant.components.system_log.external] Automations: door_sensor1_status open to closed
... no more door_sensor1_status warning
Is there a solution for this ?
