Hi Everyone,
I got a little bit further on this:
-I own 2 MCO Home switches: S411 (single button) and a S412 (dual button).
-In the meantime I moved over to an Intel NUC, and did a fresh install of HA. I also reset all my Z-Wave devices to factory defaults, including the Aeotec z stick.
-The manual of the MCO Home switches state that it supports the following Z-wave groups for direct associations:
411:
Group 1 - Lifeline
Group 2 - Button 1
412:
Group 1 - Lifeline
Group 2 - Button 1
Group 3 - Button 2
-Now, the case was that the MCO switches did respond when switched from the HA WebUI (and did it fast)
-When the S412 on the MCO home switches however, it did not provide the state back to hassio, and thus did not turn off the switch in the HA WebUI.
-The S411 did actually work normally
-So I opened the Z-wave logs, and noticed no messages came across at all from the MCO home S412
-Then, suddenly I started realizing that it could have something to do with assiciation groups, since they were not working before either
-I checked te association groups, and bingo, found the following:
411:
Group 1 -
Association: Aeotec Z-stick
Group 2 -
412:
Group 1 - Button 1
Group 2 - Button 2
Group 3 - Lifeline
-For some reason, the Association group of S412 is messed up, and the Aeotec should be associated with Group one (even if called “Button 1”, which seems to be incorrect). Now, my assiciations look like this:
411:
Group 1 -
Group 2 -
412:
Group 1 - Button 1
Group 2 - Button 2
Group 3 - Lifeline
-Now the S412 does report its state to the WebUI, and does it fast as you would expect, this issue is solved!
-But I wanted to do some more. I wanted to associate the S411 to one of the buttons of the S412, so changed my associations again:
411:
Group 1 -
Group 2 -
Association: 412
412:
Group 1 - Button 1
Group 2 - Button 2
Association: 411
Group 3 - Lifeline
Results:
-Everything is off
-When pressing button 1 of the 412, the 411 switches on
-When pressing again, 412 button 1 switches off, 411 remains on
-Also the WebUI is not responding well anymore for the 412 (it’s slow again / does not always respond)
-Switched all off again
-When pressing the button of the 411, switch 412 does not switch on (or off) at all
So the associations do not work very well, especcialy from the S412. Anyone similar issues, or know how to fix this?
Maybe it has something to do with not being able to control which button to be controlled of the S412. In the association of the S411, I am not able to choose which button of the S412 to switch. Anyone knows how to do that?
Kind regards,
Anthony
